Results 21 to 29 of 29
Thread: P0690 Code help
04-26-2020 #21Registered User
- Apr 2018
- 33
04-26-2020 #22Registered User
- Jul 2017
- Nashville, TN
- 97
So I re ran the checks as suggested.
Ignition on: 30 12v, 85 12v, 86 ground, 87 12v
Ignition off : 30 12v, 85 0v, 86 open circuit, 87 7v.
I tested the wire that comes into the fuse block at 87 with the relay out of the fuse block. There is 7v there when the car is off and 6.3v when ignition is on. Should there be voltage at this wire with the car off? Does low voltage there when off indicate a short or a back feed?
04-26-2020 #23Registered User
- Apr 2018
- 33
I'd have to check on a similar system. The voltage checks would normally be done with the relay in circuit.
GM tells you to use 2011 or so Camaro for service information. The powertrain relay is wired differently in the Camaro compared to the GMPP.
04-27-2020 #24Registered User
- Apr 2018
- 33
Checked on a vehicle in shop today, had LS7. Removed Powertrain relay, cycled ignition, left off, probed terminals.
Term 30 12.7V, Term 87 0V, Term 86 12.6v, Term 85 0V. Cleared P1682 code afterwards.
This vehicle has the GM trans computer that plugs in to the bulkhead connector.
I feel something is suspect with your harness. Is there anything connected to your bulkhead connector?
According to GM instruction sheets, the LS engine control kits all use the same engine harness.
04-27-2020 #25Registered User
- Jul 2017
- Nashville, TN
- 97
Kind of as I suspected I seem to be getting some sort of power feed back into the harness. Of course the bulkhead connector in question is buried deep within the fender well and will not be easy to get to. Would have to pull the whole fender to get to it . Thanks so much for the confirmation, I assume that 6v I am seeing at the pin 87 wire with Ignition off is my issue. I will track it down and at least I know where to start. Any clue what in the bulk head may tie to the wire that feeds pin 87 on the Pt relay?
04-27-2020 #26Registered User
- Apr 2018
- 33
Can't say. Quick test would be to remove the fuses labeled bulkhead in the GMPP fuse/relay box though.
04-27-2020 #27Registered User
- Jul 2017
- Nashville, TN
- 97
Yeah I plan on pulling some fuses to help track this down. Hopefully I can track this issue down.
04-28-2020 #28Registered User
- Jul 2017
- Nashville, TN
- 97
So after testing a few fuses and relays I think I have found the issue. Relay 3 for the dual fan setup has a constant 12v wired to pin 86 and it should be a 12v switched. When that relay is out of the equation the P0690 and the 7v at pin 87 of the PT relay is gone. Have to open up the fuse block and change the wire, fingers crossed I can get to it without taking too much apart.
05-01-2020 #29Registered User
- Jul 2017
- Nashville, TN
- 97
Made the change in the fuse block and all is good. No more check engine and no more phantom voltage at the PT relay. Thanks for all the help.
