    Results 1 to 11 of 11
      Dec 2018
      Houston, TX
      Tilton 3 Pedal Assembly & 3-in-1 reservoir (Hard to Find)
      I am going a different direction on the pedal setup in my Nova so my loss is your gain. Offering up a Tilton 800 Series 3-Pedal floor mount setup (Tilton 72-850) with the balance bars included and designed for pivot-mount master cylinders. The throttle pedal is designed for both drive-by-wire and cable driven applications.
      3 Pedal Assembly ($500)
      3-in-1 Reservoir ($500) SOLD
      Text/Call (713)449-one5four1
      Jeremiah
      Dec 2018
      Houston, TX
      Open to reasonable offers...
      Dec 2018
      Houston, TX
      Price Drop
      Quote Originally Posted by jeremiahbelk View Post
      I am going a different direction on the pedal setup in my Nova so my loss is your gain. Offering up a Tilton 800 Series 3-Pedal floor mount setup (Tilton 72-850) with the balance bars included and designed for pivot-mount master cylinders. The throttle pedal is designed for both drive-by-wire and cable driven applications. Also available is the hard to find metal Tilton 3-in-1 reservoir (Tilton 72-570) for front/rear brakes and clutch chambers. I have double the asking prices in each of these.
      3 Pedal Assembly ($650)
      3-in-1 Reservoir ($400)
      Package for both ($900)
      Shipping to lower 48 at buyers expense
      Located in Houston, TX
      Jeremiah
      Dec 2018
      Houston, TX
      3-in-1 reservoir SOLD
      3 Pedal Assembly NEW PRICE $500 - This assembly is new / never used or installed / paid over $1000 originally.
      Nov 2009
      Austin Texas
      These mount the master cylinders in the car correct? Behind the pedals?
      Dec 2018
      Houston, TX
      cwylie
      They actually mount underneath the pedals in the pedal assembly. Feel free to text me for a video.
      Jeremiah
      Dec 2018
      Houston, TX
      Bump.......
      Jeremiah
      Dec 2018
      Houston, TX
Size:  231.5 KBName:  titlon 1.jpg
      Scottsdale, AZ
      Im curious if you have any pics of the pedals mocked up on the floor of the car? Do they interfere with the steering column? How did you plan installing them? I'm imagining a pedal box in the floor?
      69 Camaro
      Art Morrison C6 Subframe
      Art Morrison Tri-4 link
      Dec 2018
      Houston, TX
      pedal mockup - Tilton 3 pedal assembly
      We sat this assembly in the car but they were never mocked up. I am running a roadster shop chassis under the Nova. I had originally imagined a floor mount setup like the high end Porches, Lamborghini's, and Ferrari's so I bought all of the parts I planned to install. Once the body was mated to the chassis and floors were fabricated, we realized that the main RS square tube frame ran right thru where the pedals needed to be recessed and mounted. If we had run a DSE, Heidts, or another aftermarket front clip, there would have worked perfectly. You have wiggle room to move the pedal assembly right or left to accommodate for your column. You can actually mount the assembly as far back as the firewall or as far forward as you can to accommodate for a shorter or taller driver. And once mounted, the pedal pads themselves can be adjusted for driver comfort. Hope this helps.
      Jeremiah
      Dec 2018
      Houston, TX
      Price drop
      $425
