Results 41 to 52 of 52
08-26-2020 #41Registered User
- Sep 2004
- Fresno, Ca
- 379
I know this thread seems to have lost momentum, but I've been contemplating the Terminator X vs MS3Pro Ultimate lately for a 400/5 speed combo...
The 'universal' Term X kit should work if you add a 24x or 58x reluctor wheel for a crank position sensor.
The cam sensor can be purchased through Luhn Performance in Wisconsin, or you can make one from an old distributor and a Hall Effect sensor(well, I'm hoping the Holley can use that setup), or Holley markets a dual sync dist. that can kill multiple birds for you...
For me, I have an Offy 2x4 intake, a Holley LS 2x4 adapter lower, and will be sourcing a 105mm top, and a tapered 105mm throttle body (unless the math shows that a 92mm setup will work, because that's WAY cheaper on the wallet).
I also have LS truck coils. I'm hoping I can emulate what the ECU wants for an LS, or that the Term X will be able to understand what I'm doing and run with it (no pun intended) because the MS3 can.
08-26-2020 #42Registered User
- May 2015
- Island Lake, IL
- 815
