03-22-2020 #1
2 Questions on Firewall and taillight housing repair.
First question. Had some pitting in an area of rust that I sanded with a wire brush. Is this typically addressed with a skim coat/body filler or does this actually get welded similar to replacing panels on larger areas? This is a very large picture of a very small area.
Second Question - the area around the Master cylinder appears thin compared to other areas and has some flex. Is this typical and should it be replaced or reinforced.
Thanks for any suggestions.
