      Ontario, Canada
      Magnum rear seal
      I have a leaky output shaft seal on my T56 Magnum and want to replace it. I would like to get one locally but haven't had any luck. I really don't want to mail order such a small and probably inexpensive part.
      I can find lots of part numbers but the ones I have tried are wrong. Of course there are a lot more part numbers out there but they are useless without the name of the manufacturer.
      I find it hard to believe that Tremec is the only company using this particular seal. Surely it was used on something more common. I have heard that it is the same size as some Ford seals and maybe a Viper seal but can't confirm.
      I'm on the verge of pulling my hair out and don't have any to spare so any help would be appreciated.
      Ken
      My other car is a Vega.
      Dec 2008
      Detroit
      Viper seal works, I had the same issue. There is also a thread here about verifying the tailshaft has drainback holes machined.
      https://www.pro-touring.com/threads/...Magnum-trouble
      I will see if I can find the part number...
      Big dreams, small pockets....
      Chris--
      '72 Cutlass S LSA/T56 Magnum
      Project Motor City Madness
      Ontario, Canada
      The drain holes were the first thing I looked for after pulling the seal out. I have them.
      That thread did lead me to a response from btmatt saying he used a seal for a '66 - '76 Ford F150 with a C6. In a later post he states the seal is working fine.
      The parts guy is gonna be like when I walk in tomorrow.
      Ken
      Nov 2014
      Feb 2016
      Lawrenceville, IL
      We use the part# 11424 rear seal from NAPA. It should cross over to a Ford C6 automatic. They don't have the extended dust boot, but works great.
      visit us on the web at www.bowlertransmissions.com
      Ontario, Canada
      I can't remember if the part number is the same but I did use a C-6 seal. Apparently they are available with and without the boot and with or without a flange. I chose flange with no boot. I haven't driven it yet, but it fits much tighter.
      Thanks for all the help guys.
      FYI - A piece of 2" black ABS pipe makes an excellent installation tool.
      Ken
