      Dec 2011
      santa rosa calif
      1969 firebird ls swaped 25k obo
      1969 firebird ls swap lq4 rebuilt with cam 4l60 trans b&m shifter . fitech ultimate with trans controller .headers ict billit pulleys aluminum radiator with duel fans new hoses waterpump thermostat and housing new belts . all black braided lines vintage air bulkhead fittings new front light harness new rear light harness . new close ratio steering gear box powdercoated subframe and inner fender wells . Viking double adjustable coilovers , tubular a arms new holley transmission crossmember new aluminum subframe mounts and comp spec subframe connectors .. new vintage protouring gauges with adapter for firebird cluster . new wheels and tires new billit steering wheel . new tanks inc narrowed tank and fuel pump . new driveline . vintage air heater kit . i still have some stuff still in boxes laying around that i will include
      this car has newer interior and runs but needs wiring and finish work the paint is good at 10 feet car is pretty solid someone did a crappy job on floorpan in rear d.s it needs to be finished and driven for the fitech to tune . this is still a builder imo
      the car is located in Sonoma ca. i'm sure I forgot some stuff Name:  FB_IMG_1559789273951.jpg
Size:  63.9 KBAttachment 173221
      Oct 2018
      San Jose, CA
      Good looking bird !
      1971 Camaro - 406 / T56
      2016 Camaro SS convertible
      2018 Colorado 4x4
      Dec 2011
      santa rosa calif
      still for sale no I won't take 15k
      Mar 2020
      Can you please go into further detail on the floor pan issue?
      Any interest in selling the front clip with the motor?
      Dec 2011
      santa rosa calif
      no I wont part . just need minor rust repair part is 20.00 if you just wanna fix just the rust in the rear I already have the front but it doesn't need it the steel is fine
      Dec 2011
      santa rosa calif
      1969 firebird
      back up for sale did a few more things to it new grilles more powdercoating on bumper brackets and such still 25k
      Feb 2017
      San Ramon, CA
      Quote Originally Posted by darkling View Post
      Is this still available?
