    Results 1 to 9 of 9
      Mar 2015
      Vintage Air Bulkhead
      Has any one found a way to use AN fittings for heater hoses using a vintage air 4 way bulkhead. I think the bulkhead is#10 O-ring. So will need to go from O-ring to AN.
      Oct 2018
      Phoenix, AZ
      I'm not aware of there being and off-the-shelf solution for that. You'd be better off just getting AN bulkheads instead. Although, I'm not sure that AN lines have the AC service ports available or are rated to handle r134a, but I could be wrong.
      If it matters, I'm using the VA bulkhead with their hoses and it's working great.
      For the refrigerant lines, the o-ring is a more reliable sealing method, less sensitive to assembly issues. may want to consider keeping it.
      Greg Fast
      1970 Camaro RS Clone
      1984 el Camino
      Nov 2009
      Peoria, Az
      He may only be referring to the heater lines and not the ac lines.
      Mar 2015
      Yes just looking to do the heater lines.
      Central Florida
      KCR,
      I think these would work, they are ac but should go for heater hose as well. I have used these before but made by a racing company and cant find where I bought them now.
      https://www.ebay.com/itm/Male-Insert....c100005.m1851
      Hope this work out
      BB
      Quote Originally Posted by djorgensen3 View Post
      You know, I would sound a while lot smarter if I had better reading comprehension.
      Greg Fast
      1984 el Camino
      Nov 2009
      Peoria, Az
      Happens to me all the time....ask my kids....
      Jan 2010
      Louisville, KY
      I have these but I haven't used them yet so I can't vouch for their function. Looks to be the same thing BB posted but less expensive.
      https://www.aeroflowperformance.com/...r-bulkhead-1pc
