    Results 1 to 15 of 15
      Feb 2010
      Bay Area California
      Spun bearing on LS7 with wet sump conversion
      Hey all,
      Looks like I spun a bearing on my LS7. I am thinking of buying a new motor, probably an LS3 crate, and was looking for options. Is there anywhere I should be looking as the prices on gmperformance.com are pretty crazy. I do want a brand new motor so I am not looking for rebuilds. Thanks in advance for the suggestions.
      p.s. also looking to have the LS7 rebuilt by someone local to Bay Area in Cali.
      1969 Camaro
      LSX 454
      Boze Autocross 18x9 front 19X10 rear
      Marquez full interior
      Recaro seats
      TCI front clip
      TCI rear torque arm suspension
      Currie F9 9" rear
      Willwood 6 piston calipers front
      Willwood 4 piston calipers rear
      Ididtit push button start steering column
      E-Stopp electronic e-brake
      Jun 2010
      Deployed
      Quote Originally Posted by jat5150 View Post
      Hey all,
      if the block isn’t damaged, I personally would give Texas Speed a call. They could surely set you up to bring it back to life. A 440ci LS would blow the doors off a crate LS3
      What do you think happened? Sucked the pan dry? Aeration? Lost pressure do to O-ring failure?
      1970 Camaro/DSE build
      Feb 2010
      Bay Area California
      Unfortunately I don't know, we are going to take the motor out and take a quick peak. I have never worked on an engine so not really sure what to look for.
      1969 Camaro
      LSX 454
      Recaro seats
      TCI front clip
      Currie F9 9" rear
      Jun 2010
      Deployed
      what was the scenario? Shortly after the wet sump conversion? Driving at high rpms? Normal driving? Notice any loss of oil pressure?
      Feb 2010
      Bay Area California
      I would say yeah, shortly after conversion as the motor only has @500 miles on it =). At the time I noticed something went wrong, it was at high rpm's (I came of the light pretty hard and went through gears pretty quickly (gotta have fun right). I noticed there was a loss of oil pressure shortly after, and it stayed low all the way home.
      1969 Camaro
      LSX 454
      Recaro seats
      TCI front clip
      Currie F9 9" rear
      Feb 2011
      dallas, tx
      Sure it’s a bearing and you didn’t take out a lifter?
      Sep 2017
      I would have been scared ton drive it home if i saw low pressure after a hard run.
      Wreckers are cheap compared to an engine
      TANKMASTERJ
      Jasons Toys
      2000 HD Softail
      Jun 2010
      Deployed
      The O-ring on the pick-up tube is notorious for being pinched or torn causing low OP. High RPMS can also suck a pan dry too. I agree, it might not be a bearing...
      Feb 2010
      Bay Area California
      Turns out it was what we thought it was! Spun bearings on 5&6 and all of the bearings and crank have some amount of scuffing.
Size:  81.5 KBName:  IMG_8923.jpg
      Now onto the hard part, looking for a solid builder as well as a new motor! Thinking LSX as I don't want to mess around with another LS7 at this point, but not sure. Decisions....decisions...decisions....
      If you have suggestions please feel free to throw them out there. I am looking for a LS series motor, could be LS3 supercharged, LSX, all I want is that the new motor has to be something more sexy than an LS7.
      1969 Camaro
      LSX 454
      Recaro seats
      TCI front clip
      Currie F9 9" rear
      NJ
      Oh man that stinks. Was it a bare bones LS7 converted to wet sump?
      I have read good things about HPR (Horsepower Research) and Texas Speed on other forums I participate in.
      Feb 2011
      dallas, tx
      You wouldn’t have happen to install a oil cooler adapter did you?
      Feb 2010
      Bay Area California
      No i didn't install an oil cooler, why do you ask?
      - - - Updated - - -
      Quote Originally Posted by John McIntire View Post
      It was a bare bones LS7 converted to wet sump.
      1969 Camaro
      LSX 454
      Recaro seats
      TCI front clip
      Currie F9 9" rear
      Oct 2018
      Phoenix, AZ
      I'll second that suggestion to call HPR (Horsepower Research). I know those guys personally and worked for one of them a decade ago. They work with people/shops all over the country and know their stuff. Erik will build anything you can dream of if it is physically possible.
      Feb 2010
      Bay Area California
      Thanks, I will give them a call should I give him a name that referred me to him? If so whats your name?
      1969 Camaro
      LSX 454
      Recaro seats
      TCI front clip
      Currie F9 9" rear
      Oct 2018
      Phoenix, AZ
      Not sure telling him Sean sent you will mean much these days since we haven't really talked much in a while. You're welcome to mention it nonetheless.
