    Page 1 of 6 1 2 3 4 5 6 LastLast
    Results 1 to 20 of 103
      Jan 2013
      ST George UT
      Just another 69 Camaro, DSE LS427 twin turbo
      Started working on my 69 Camaro again, Its been about 2 years.
      Small list on what parts are here as of today.
      -Car was taken down to metal.
      -Rear spoiler was molded in and laid back.
      -Rear bumper was hand built and pocket into the car.
      -Side marker light shaved.
      -Kindig-it door handles installed.
      -Drip rails shaved.
      -All factory body spot welds and normal imperfections smoothed.
      -Firewall smoothed.
      -Smoothed dash speaker grill.
      -Body had been primed and blocked 6 times for show car finish.
      -DSE mini tubs.
      Now for the good stuff.
      Engine & transmission:
      -RHS LSX 427 all aluminum block.
      -Callies dragon slayer crank.
      -Callie Ultra rods.
      -Wiseco custom billet forged turbo pistons.
      -Mast motorsports heads built by LME to match.
      -Titanium instake valves.
      -Inconel Exhaust valves.
      -8 pac racing valve springs.
      -Rpm racing rocker arms with Smith brothers grunion kit.
      -Smith Brothers push rods.
      -ARP stud kit.
      -GP tuning turbo cam.
      -Billet timing chain.
      -LME billet intake with dual injectors and dual electric throttle bodies.
      -LME billet valve covers.
      -Nelson 88 mm twin turbo.
      -Blow off valve.
      -Dome pressure sensors.
      -60 m waste gates.
      -Magnum T56
      -Bullet proof scatter shield.
      -McLeod Daul disc clutch kit.
      -Billet flywheel.
      -McLeod Clutch master cylinder.
      -McLeod Clutch throw out bearing.
      -Holley Dominator EFI module
      -Holley dual injector driver module.
      -Holley traction control module.
      -Concept-One front pulls set up.
      -Stainless work turbo headers.
      -Custom 3" Stainless mandrel bent tightly welded exhaust all the way out the back.
      Front suspension:
      -DSE Hydroformed sub frame, powder coated and complete with coil over and rack and pinion steering, spline sway bar.
      Rear suspension:
      -DSE quadra link with dual adjustable coil overs.
      -DSE sway bar.
      -DSE rear tow hooks.
      -Mosser 12 narrowed 12 bolt.
      Brakes:
      -Baer 6 piston front
      -Baer 6 piston rear bakes with E-brake.
      -Baer re master black master cylinder.
      -Hot Rod shop Hydro boost kit.
      -Hand built stainless steel lines.
      Fuel:
      -Ricks custom stainless tank, custom 3 Walbro 450 pumps camaro style module assembly.
      -Stainless steel hand built lines.
      Extra:
      -DSE mini tubs
      -DSE exhaust trunk clearance.
      -DSE trunk fuel door.
      -DSE floor spring pocket braces.
      -DSE weld in sub frame connectors.
      -Bowler raised transmission tunnel.
      -Ring Brothers Billet hood hinges Air frame
      -Ring Brothers billet trunk hinges.
      -Ring Brothers billet door strikers.
      -Ring brother black hood adjusters
      -Billet black door sill plates
      -Ring brother black billet door vents
      -Custom Billet trunk latch.
      -Eddie Motor sports billet tail lights.
      -Sequential LED tail lights.
      -American Auto wire car wire harness.
      -NuRelic power windows.
      -Ididit tilt steering column.
      -Rain Gear hidden wiper kit.
      -Vintage a/c kit.
      -Vintage a/c 3 knob controller.
      -New black stock dash gauge bezel.
      -Budnik billet steering wheel.
      -R/S front grill.
      -American heart beat electric r/s headlight door conversion.
      -Anvil carbon wiper cowl panel with vent delete.
      -AutoRad complete aluminum radiator support with aluminum radiator, inner coolers.
      -DSE radiator close out panel.
      -Marquez Hand built front bumper.
      -Forgeline wheels 19X12 rear 18X9 front
      -Michelin Pilot sport tire.
      -Clayton billet pedal assembly.
      -Clayton drive by wire pedal assembly.
      -Fesler front and rear flush mount glass kit. All body work done to fit the glass.
      -New smoked side glass kit.
      -All modules and coils are mounted inside the car on custom brackets.
      -Dakota Digital HDX gauges.
      -E-Stop Electric E-brake.
      -LLC Shop rear package tray wrapped in black leather.
      -LLC shop speaker box for DSE car.
      -Billet trunk mounted battery bracket.
      -Optima battery.
      -American auto wire battery shut off and remote jumper leads.
      -polished Billet R/S headlight door covers.
      -New felts, seals, gaskets
      -New door latch's
      -Power trunk kit
      -Billet ride billet left and right outer mirrors.
      -Billet ride black billet inside rearview mirror.
      Got the motor and trans mocked in there this weekend. Only took 3 times in and out.
      I am still on the fence with LME dual throttle body, dual injectors with mirror 88mm twin turbo or Whipple Supercharger......
      Jan 2013
      ST George UT
      1969 Camaro DSE twin Turbo
      Auto Rad Radiator installed. Transmission tunnel is cut out for TR6060, Bowler trans tunnel kit ready to get welded in.
      Inner fender and front sheet metal this week.
      Still not 100%, should I go Whipple super charger or Nelson twin turbo?
      I bought both for this car.
      Dec 2018
      I really like the look of the Nelson mirror setup, personally.
      Who did you have do the body work and tub work?
      NJ
      That thing is going to a handful for sure! The Nelson set up is super nice and clean. The mirror image turbos keep everything symmetrical and his billet intake is very stealth looking with the integrated fuel rails and hidden injectors.
      Have anymore pics of the Autorad setup?
      Jan 2013
      ST George UT
      So got the turbos mounted and down pipes made.
      Also got the DSE exhaust trunk cut outs installed.
      DSE gas door installed.
      Baer brakes installed.
      I have to install the R/S grill to finish the rest of turbo piping.
      Jan 2013
      ST George UT
      Got all the plumbing done for the turbos.
      Jan 2013
      ST George UT
      Brakes, Turbos done.
      Starting on the exhaust, turbos all done, front and rear brakes installed.
      New twin disc clutch and T56 Magnum installed. I like the Holley T56 transmission cross member. Plenty of room for 3" exhaust. Fit great with DSE front clip.
      Started wiring in Holley Dominator and also added thier traction control module.
      Ricks tank is power coated and installed. Should be a running in a couple weeks.
      Chicago
      Stunning engine bay and hell the rest of the car is just as nice.
      marty-mj
      Feb 2019
      Easley, SC
      Looks amazing!!! Nice work.
      Pro Touring Store: Your parts source for all things Pro Touring! We have the best prices & service from suspension, to crate engine packages, to billet accessories and much more!
      www.ProTouringStore.com
      (Not affiliated with Pro-Touring.com)
      Jan 2013
      ST George UT
      Steam lines all done
Size:  228.4 KBName:  IMG_1294.JPG
Size:  292.2 KBName:  IMG_1296.JPG
Size:  293.0 KBExhaust is all done. Name:  IMG_1204.jpg
      Jan 2013
      ST George UT
      Almost ready to drive.
      DSE sub frame connectors
      DSE fuel access door.
      DSE heavy duty floor pocket kits installed.
Size:  482.9 KBName:  IMG_1486.JPG
Size:  466.3 KBName:  IMG_1489.jpg
Size:  142.5 KBName:  IMG_1482.JPG
      Jan 2013
      ST George UT
      1969 Camaro Twin Turbo LS427 DSE
      Wheels and tires finally arrived. Thank you Forgeline.
      She is on the ground. Hope to start up next week.
      Nov 2009
      Austin Texas
      18 or 19 inch wheels?
      Jan 2013
      ST George UT
      18 fronts
      19 rears
      Dec 2018
      Quote Originally Posted by classiccarcustoms View Post
      18 fronts
      19 rears
      I did the same thing, but there didn't seem to be many options for matching tires. Ended up going with Michelin Pilot SP2s to make it work.
      NJ
      Awesome! Looking real good!
      I see you're using the Holley trans cross member on the DSE subframe. What motor mounts are you using and did you have any issues using it?
      Jan 2013
      ST George UT
      Holley cross member worked out great with DSE frame and Magnum T56.
      Engine mounts I bought DSE LS kit but I moved the engine back another 1.5” to make room for turbo piping.
      NJ
      DSE makes a mount kit to move the engine back 1.5 inches, which is what I have. Are you saying you moved the engine back another 1.5 inches, for a total of 3 inches? That would be pretty far back and would require some severe firewall mods based on what I see now with my 1.5 setback.
      Nov 2018
      Nice car, looks well thought out. How are you controlling the dual throttle bodies? Are they DBW or cable? I'm considering a very similar setup for my project, and one of the end pieces involved a turbocharged LS-based 427 with twin throttle bodies using this intake. Hadn't figured a way to run a pair of DBW throttles this way. Mine will be a little more complicated because I have to run an automatic, and will be running at least a 6 speed auto, so I have to run the factory computer. And, have you had it running on the road yet? How's the power and response, and how quickly does it build RPM?
