    Results 1 to 20 of 36
      Jan 2022
      engine size autocross
      I hope this is in the right place to post I was wondering about what motor I should put in my 69 vette flared 315 squared t56 willwood big brake kit borgeson box t56 6 speed .I know everybody will say ls all the way and I agree but I not want to spend the 16 grand to do it meaning changing all my pulley set up and custom exhaust, this car is primarily used for autocross I was thinking about a blue print 427 or 454 small block the 454 makes 580 hp at 6000 and 570 trq at 4600 not bad for the price with a msd ignition all said and done about 10 grand with a warranty and my second option would be a destroked 406 to a 377 that would have a dart shp block scat crank and rods afr heads and make about 560 hp and 500 trq and rev to 7000 all day long long any thoughts will be appreciated. thanks .
      Nov 2018
      I don't know if you'd be happy adding big block weight to the nose. Autocrossing is handling first and foremost and adding weight to the nose is going to make it more prone to plowing during hard cornering. A Dart aluminim small block would be a better option IMO, and all your existing external parts (accessories, headers, ect) would bolt right on. In fact, nobody would need to even know you made a change.
      This is an engine I always wanted to build, at least until the LS came along - a short stroke long rod 350. This link goes over a Chevy 350 (The 350 Engine Chevrolet Should Have Built) that uses a bored out small block 400 with a 327's 3.25 stroke crank to make 350 cubes, and uses long rods which will allow 87 octane on 11:1 compression. This article is pretty old but even back then they were able to get 412HP at 5700RPM and 435TQ at 3500RPM, and more importantly the engine made over 400TQ from 2800RPM to 5200RPM. I think using a Dart aluminum block, modern heads, a lightened crank and a modern aftermarket fuel injection setup you could probably get closer to 500HP/TQ without the huge weight penalty of a big block. Plus, a short stroke engine winds up in a big hurry when you hit the go pedal, which is lots of fun.
      2021 Durango R/T
      2005 Dakota beater
      2003 Dakota project-o-mobile
      Jan 2022
      yes
      The motor would be a 377 from a dart shp 400 block and with afr heads and all the good parts makes about 560 to 570 hp at 6800 rpm with about 500 trq, or I go with a blueprint 454 small block with a good intake and carb and ignition and will run at about 580 hp at 6000 rpm and 570 trq at 4600 either way they are about the same price 10 grand .
      Close or Wide ratio T56, and what rearend ratio?
      Also one hint (granted I'm no expert so hopefully more will jump in) since Autocross tracks are pretty short, I think a broad and flat torque curve works best. You'll mostly be using a couple gears if you have it setup right. Broader minimizes the gear changes as you setup transitioning from corner to corner (big savings in time and keeps the tire loading changes less abrupt). And flatter keeps the power very predictable for the driver regardless of the track.
      So just looking at the Blueprint engines, the 427 seems to have power that is both slightly wider and a little more flat than the 454. With the torque it puts out, you could throttle out of a corner at 2600rpm and go up to 6200rpm without shifting if you needed to.
      I'm not sure if a de-stroked would be preferred or not. It'll rev faster, but you'll want steep gearing to make it strong coming off a corner, and then really spin it up before the next corner.
      Jan 2022
      specs
      370 rear gear t56 is 266 first and I think a .64 6th 30 inch tall tire .
      Jan 2022
      yes
      I do agree with the torque curve on the 427 I am in first gear the whole time at good guys autocross and 1st and second at another venue but with that much power I could stay in second the whole time and even lug it a bit in the turns barely throttle my little 350 I have to rev the piss out of it its gutless.
      Jan 2022
      Am I wrong to look at it like when I ride my dirt bikes and my 4 stroke is awesome cuz I can stay in 3rd or 4th while my buddies 2 stroke he is 2 to 3 gears versus 1 of mine .
      Jan 2022
      my other ride
      This is my other ride and it is machine in a half and I like the power curve in it and I think it would do well in autocross .Name:  new side shot side pipes.jpg
Size:  36.6 KBName:  new side shot side pipes.jpg
      Jan 2022
      my 69 vette
      Here's my 69 vette t56 borgeson box 315 squared vansteele front and ride tech rear suspension .
      Sep 2014
      Those are both great looking Corvettes! I have a strong want for a 70-72 Corvette that I could autocross. Seeing yours isn't helping. lol. I had to pass on a cheap local red on red 72 last summer with a non numbers matching 350 and a bad rear subframe. The perfect project. But I have 65 GMC I have to finish first.
      Quote Originally Posted by c3rocket View Post
      In my opinion (I'm no expert either) I would want a destroked engine because any of the cars I've co-driven at autocross with a flat torque curve overwhelm the rear tires coming out of corner too easily. Moving the powerband up makes it easier to get on the power sooner.
      Short and wide 1965 GMC 910.
      There's also a BluePrint 400, which has the same bore, but shorter stroke than the 427. About 75ft-lb less torque on the lower end, still very flat, and looks like you could easily spin it up to 6500 (if they say the valvetrain is up to it).
      Jul 2017
      Island Lake, IL
      I would 99% of the time take the cubic inches. So many people are into the destroke idea but RPM capability has a lot to do with valvetrain stability more than bottom end. Look at LS engines for comparison. 6.2-7.0 liter LS engines make better power than 4.8-5.3 engines but the architecture is nearly the same.
      Don’t feel like you have to go LS. Traditional V8’s can work very well and, IMO, it’s nicer buying things like radiator hoses and other parts that were originally designed for your car and bolt in. Do what feels right for yourself. Big Blocks are awesome just as LS engines are.
      Jan 2022
      I would think about a lsx but do you still have to change exhaust where headers bolt to the heads .
      Beach Park IL
      High revving engines tend to be peaky. There is no torque and then suddenly it will blow the tires off as the RPMs come up. It is difficult to drive a car like that.
      Take the engine with the flattest torque curve as it is the most predictable to drive.
      Donny
      Soo... I'm going to be that LS guy I guess. If you are planning to AutoX the car a lot, I see no better option than the LS motor. Adding lightness to vehicles seems to be the best method for being competitive in that setting. It's hard to get much lighter than an aluminum LS engine. If you are going to be all in for the 454 SBC at $10k, I'm confident that you could piece together an LS swap for around that price. GM has a Crate LS3 430HP engine for $5k. (Granted, you may have to wait given the shortage) I'd grab a Summit Cam kit, Terminator X Max, stock loaded LS3 intake and find someone selling C6 Vette accessories. I'm sure someone makes mounts, oil pan and headers for a C3. Not sure what you are doing for a fuel system, but I ran a stock 5th gen Camaro fuel pump assembly that was modified by vaporworx that was pretty inexpensive.
      There are literally a million different combinations that could be suggested for an "LS" swap, but I think this one would meet all of your goals. 2 year warranty, and not kill the bank.
      Even if you aren't making the same power as the 454 SBC, you are much lighter up front and the LS motors love to rev. LS3 Vette/Camaro guys usually make 450 rwhp with H/C/I. Then if that isn't enough, swap on an LSA supercharger.
      Keep us posted on what you end up doing.
      Sep 2014
      Quote Originally Posted by Jonathonar89 View Post
      The key is combining them both. I'm currently considering a 6.2 block with a 4.8 crank for a total of 5.5 litres that'll rev to 8000 rpm and make about 600 horsepower naturally aspirated.
      https://www.motortrend.com/how-to/4-...pm-ls-stroker/
      I've autocrossed a C6 Corvette Z06 and in no way was it peaky at all. It also wasn't difficult to drive and is very competitive. I liked how easy it was to drive at autocross, even on a tight course.
      Beach Park IL
      In attempting to contradict me you are making my point, thanks! The LS7, even cammed to match the theoretical HP output of you 5.5 liter screamer, will be waaaay easier to drive......because flat and predictable torque curve. The LS7 is awesome but it's a pretty mild engine.
      From the link you posted
      the 339-inch motor produced 607 hp at 7,900 rpm and 466 lb-ft of torque at 6,200 rpm.
      That's going to suck to autocross
      Donny
      Sep 2014
      From the link you posted That's going to suck to autocross
      While I agree that upon first glance the engine at the link I posted could be considered peaky, I'm not looking to build an exact copy. Those horsepower and torque numbers are also on an engine dyno so they are gross, not net so once it's in a car, it's probably close to the LS7's 505 horsepower.
      The LS7 makes 475 lb-ft at 4800 RPM, which is still pretty high. I've also autocrossed a 2008 BMW M3 V8 which only makes 295 lb-ft at 3900 rpm. It makes 414 horsepower at 8500 RPM and was also really good to autocross.
      I disagree that a higher torque peak can't still have a flat and predicable curve. I want a responsive engine that revs and not a burnout machine.
      Aug 2012
      Peoria, AZ
      Everyone has been after me to LS swap my SBC for years. Even when I hurt it couple years ago, it still made WAY more sense to freshen up the SBC than to LS swap it.
      I feed and control my Fastburn 383 with a Holley Terminator 4bbl system and I'd challenge anyone to tell me it's not an LS if they drove it without looking under the hood. Well except for the killer torque it makes from 2,000 rom and up that is. It pulls out of holes way harder than any LS3 I've driven. I haven't dyno'd mine but paper calculator shows 525 hp (peak 5400), 550 ft lb (peak 4700) and it's VERY driveable and has beaten a ton of LS swapped cars over the years.
      Lance
