    Results 1 to 16 of 16
      Jan 2000
      Thousand Oaks California
      Best LS to supercharge on a budget?
      Is there a combination of a budget takeout LS motor that would accept a budget supercharger?
      I assume not but it can't hurt to ask.
      I am kicking around the idea of a budget LS motor for the '55 Bel Air and later down the road supercharging it.
      Is there a LS engine that would accept a supercharger from something that maybe has been pulled to replace it with the latest and greatest? For example I hear there may be a new supercharger that replaces the factory LSA supercharger? I could see people replacing the stock LSA supercharger and selling them?
      Thoughts?
      Larry Callahan
      Nov 2014
      Sloppy Mechanics raves on the LY6 truck motor
      LY6 has the matching, higher flowing ports (so no rectangle to cathedral port adapter needed). Just do a VVT delete and pick a good positive-displacement compatible camshaft with about .600" lift and matching valvetrain upgrades (springs and rockers).
      I'd also update to LS9 head gaskets.
      Jan 2000
      Any chance there is an all aluminum version without VVT that an LSA supercharger would drop onto at a later date? I'm trying not to shoot myself in the foot in the future.
      Larry Callahan
      Quote Originally Posted by Larry Callahan View Post
      LS3. But @ 10.7:1 compression, you'd have a fun time keeping donation at bay with a blower.
      Jul 2009
      Sackville, NB, Canada
      The L76 from the Pontiac G8 is lower compression than the LS3 but has the same heads. Still need to do a DOD delete but it will accept an LSA.
      Tyson
      '95 Firebird Formula: suspension + 315's
      '66 Mustang Coupe, 289
      Jan 2000
      It's crazy how many options there are. Some of them are not crazy expensive.
      I think I may just ending up putting a LQ4 and a 4L80 for now and then maybe build something new and complete down the road and just swap it out. I think I may be worrying too much about this.
      Larry Callahan
      FWIW, if it were me I'd get a take-out LY6, and delete the VVT (not as many parts needed since it doesn't have AFM as well). I think you can get away with the truck intake and accessories on a Tri-5, and it'll have the rectangular port heads to mate to the LSA intake. I wouldn't worry about the weight of the iron block.
      Add LS9 stock head gaskets (they are MLS steel). Since the heads are off, you may want to sent them for porting, but that's up to you.
      Then I'd upgrade the oil pump, and add a Summit-8715 cam with 1218 PAC springs. This cam will work well naturally aspirated and pair very well when you add the blower later. So you won't have to upgrade the camshaft twice. The other nice thing about going with a cam that works as stock or with the blower, you'll be able to get all the base tuning worked out ahead, minimizing recal later. You could even update with higher flow injectors as this point too.
      If you're positive you'll be moving to the blower at a later date, you could get the brackets ahead of time https://www.lsxinnovations.com/produ...-belt-spacing/ before you put it in the car. I think it should still work with the truck intake, you'll just need a different length belt.
      Doing it this way, you start with a good NA combination that should put out nearly 500hp at the crank (even more of you had the heads ported). Then later you can swap the SC on top (along with the cooler lines) and update the cal for new injectors and boost.
      May 2020
      6.0 engines are good and are popular. But, if doing it on a budget is a real high priority, a 5.3 out of a truck can be found pretty cheaply and can be safely boosted, from what I understand, to a level that will never be able to find traction on the street.
      Feb 2011
      dallas, tx
      Budget would be a 5.3, 5.7, 6.0 and put a lsa on top of it. Either swap the heads or use adapter plates. I’m running a 2.3 heartbeat blower on mine peak 9 psi at but typically 7-8psi and it made 700rwhp at 6800rpms. I plan on turning the boost up a few more pounds this winter.
      Sep 2016
      Slidell, LA
      Here is a breakdown on what my LY6 + LSA setup has cost so far. There is no need to go as far as i have, but it will give you an idea on costs.
      If there is no cost then it was part of a kit. cost will very on these items as i bought mine last year. I bought the LSA several years ago off ebay when they where cheap.
      If i did it again i wold look for a complete LSA take out. it is the small hard to source items that eat up the budget. My engine was a GM Core so i had none of the nuts, bolts and clip that a junkyard engine would come with. The take out units i have seen come with the trans as well. so that would save you a bunch in cost as well.
      LY6 Engine Own $ 700.00
      LSA Supercharger Own $ 450.00 ZZP
      Intake Bolts LSX-LSASC6M $ 21.95 LSX Concepts
      ZL1 Supercharger Cover 12622236 $ 569.99 ZZP
      Supercharger oil 12322236 $ 8.99 ZZP
      Supercharger Coupler ZZ-LSASCCPLR $ 19.99 ZZP
      Throttle body 90mm 12605109 $ 171.99 GM
      Fuel Rail 12605222 $ 278.79 RockAuto
      Injector harness 12664869 $ 88.11 newgmparts.com
      Injector harness 12664870 $ 84.37 newgmparts.com
      Fuel Filter MP-7010-BLK $ 85.99 Summit
      fuel pressure regulator MP-99509-B9-BLK $ 221.99 Summit
      Fuel Injectors 85lbs EV6 FIC-IS303-0850H $ 675.00 Lingenfelter
      Engine Controller 19369381 $ 1,557.00 GM
      LSA Modular pulley 2.5 $ 149.99 ZZP
      ARP 234-4317 Cylinder Head Stud Kit 234-4316 $ 346.99 ZZP
      ARP 234-5608 Main Stud Kit 234-5608 $ 217.99 Summit
      ARP 134-6006 Connecting Rod Bolts 134-6006 $ 94.99 Summit not used
      Harmonic Balancer 12674581 $ 131.99 RockAuto
      Harmonic Balancer Bolt 12557840 $ 4.12 RockAuto
      Oil Pressure Sensor 12673134 $ 36.79 RockAuto
      Rear Crank seal and cover gasket BS40640 $ 16.80 RockAuto
      Intake Gaskets 12673134 $ 39.79 RockAuto
      Valley Gasket 12610141 $ 40.79 RockAuto
      Oil Galley Plug (barbell) MOGP100 $ 5.26 RockAuto
      Oil pump pickup o-ring B32790 $ 1.68 RockAuto
      Rods & Pistons, crank $ 2,249.00 Texas Speed Piston -13.7 Dish
      Lifters LS7 17122490 $ 99.99 Texas Speed
      Valve Springs 12625033 Texas Speed
      Rocker Arm Trunion Kit CHE4290 $ 109.99 ZZP had to have 4 more shipped
      Camshaft kit springs, push rods seals 12638427 $ 919.89 Texas Speed
      Camshaft Thrust Plate MF127 $ 23.79 RockAuto
      Timing Chain, Cam kit Texas Speed
      LS9 Head Gaskets 12622033 $ 123.98 Summit
      Steam Vent Kit 03-51005 $ 217.00 NO2 outlet
      3 Bolt Camshaft Timing Sprocket, Cam kit 12586481 Texas Speed
      Timing Cover 12600326 $ 119.00 Texas Speed
      Timing Chain, cam kit Texas Speed
      High Mount Accessory Drive LSA Race Drive High $ 1,947.29 LSX Concepts 12182
      Dipstick 12634547 $ 12.70 Rockauto
      Dipstick Tube 12634547 $ 14.15 Rockauto
      LS9 Piston Squirters KAT-6350 $ 183.99 Katech not used
      Timing Chain Dampener 12588670 $ 18.99 Summit
      Oil Pan 302-1 $ 349.95 Amazon
      Oil Pan Baffle 302-10 $ 168.94 Amazon
      Melling Oil Pump 10295 Texas Speed
      Radiator Custom $ 1,349.00 Entropy
      Oil Cooler Lines 625-169 $ 66.95 Dorman
      Crank Pin Kit SLP100250 $ 49.99 LSX Innovations order #4024
      VVT Delete Kit $ 119.00 Texas Speed
      Water Pump 19180610 $ 172.79 RockAuto
      Starter 12617229 $ 111.79 RockAuto
      Starter Bolts 551681 $ 11.99 Amazon
      Thermostat 187 degree 34198 $ 6.57 RockAuto
      Fuel Tank TM48A-T $ 280.00 Tanks inc.
      fuel pump GPA-6 $ 280.00 Tanks inc.
      Fuel Sending Unit TAN-GME $ 35.00 Tanks inc.
      Fuel Door AD-85 $ 45.00 Tanks inc.
      Headers Mid Length 1 7/8" 102-6794 $ 899.00 Brphotrods order#17958
      Stainless Steel Header Bolts 000-6730-00 $ 24.99 Brphotrods
      Oil Pump Pickup Tube Girdle 000-6000-00 $ 34.95 Brphotrods not used
      AFCO Heat Exchanger 80283NDP $ 459.18 Summit
      MSD Coil MSD32823 $ 352.95 Summit
      MSD Spark Plug wires MSD55118 $ 83.35 Summit
      3/8 Fitting Fuel Line EAR-AT165006ERL $ 22.66 Summit
      1/4 Fitting Fuel Line FRA-892004BL $ 25.98 Summit
      Trans Mount Ploy 000-2960-56 $ 39.99 Brphotrods
      Total $ 17,051.12
      Engine work Larry's Engine and Marine, Tuscon
      Mod block for Oilers $ 200.00
      Oil squirters MLR 401-326 $ 108.00
      Cam bearings CH-25 $ 25.85
      Hone V8 $ 75.00
      Jet Clean block $ 75.00
      install cam bearings $ 70.00
      LS O galley plug 9427693 $ 5.54
      Main bearings MS2199P-STD $ 116.94
      Enviromental Fee $ 5.54
      Total $ 681.87
      Tools
      Ring filer PRO66785 $ 56.99
      Spring compressor TFS90306 $ 79.99
      Ring compressor ARP 900-0100 $ 60.40
      Magnetic Base Harbor Freight $ 13.00
      Tread Tap ARP 912-0011 $ 53.60
      $ 263.98
      Jan 2019
      Colorado
      Quote Originally Posted by Chirus View Post
      Total $ 17,051.12
      Hone V8 $ 75.00
      Total $ 681.87
      Tools
      $ 263.98
      That's super helpful. Thanks for sharing! One question. Out of those parts what big ticket items can be eliminated for a budget build and still remain durable?
      May 2015
      Island Lake, IL
      It’s not the most cost effective but GM Performance has a small bore rectangle port cylinder head. You could technically bolt up to an LS1. The aluminum L33 has too small of a bore for this unfortunately.
      Sep 2016
      Slidell, LA
      If the focus of your build is to add to the engine in stages. I would focus on bottom end upgrades first.
      The largest issue i ran into has been finding the small parts, clips, brackets and harnesses. i would look to a complete LSA takeout engine.
      Aug 2008
      Dallas, TX
      I honestly don't think the words "budget" and "supercharger" actually go together.
      Quote Originally Posted by 509chevelle View Post
      Depends on the size of the budget...LOL
