    Dec 2019
    Ellenboro, NC
    Change shocks also?
    If I put on 2" lowering leaf springs, will I have to change shocks? What if I add a 1" lowering block to that?
    Feb 2013
    Lowering it that much will probably create the need to drop down a shock size or two from where you currently are. The best thing to do is get the car sitting like you want it to and then measure from C-C on the shock mounts. Grab that number and we can help you select the correct shock for what you've got.
    Ridetech Suspsension
    Tech Specialist
    Phone: 812.481.4734
    Project Fox
    1979 Trans Am
    Fredericksburg, VA.
    I would also add, only use lowering blocks as a last resort.
    Steve Hayes
    "Dust Off"
    68 Camaro
    Speed has never killed anyone. Suddenly becoming stationary, that's what gets you!
    "Jeremy Clarkson"
    a 2" Drop Spring AND a 1" Drop Block will necessitate a different Shock/Damper
    BMR SUSPENSION
    T.C. Davis
    813-986-9302 Phone
    813-986-8055 Fax
    [email protected]
    www.BMRSuspension.com
    Like us on Facebook!
    Apr 2015
    Ga
    Anu update, OP? What shocks did you get?
