    Results 1 to 20 of 30
    Thread: 68 Camaro build
      Jan 2020
      ORLANDO
      68 Camaro build
      So we have another 68 Camaro build thread.
      a little background... I use to have a 67 Camaro, that I built 20 but I had to sell it. No mater how many other cars I have had since I always missed my Camaro. Fueling the want was my recent racing hobby. My friend and I built a road racing corvette that we have raced at Daytona and Sebring.
      So these two cars are part of the inspiration for my new build. A first gen Camaro that can work on a track.
      Jan 2020
      ORLANDO
      So after searching I found my perfect foundation. A 68 Camaro with all metal fixed and a speedtech front sub frame.Name:  D2403DCC-1E64-4BA1-9BD0-1FDD60660770.jpg
Size:  360.0 KBName:  800749A1-AF67-4F28-B0FB-E5C87352AAD9.jpg
      Jan 2020
      ORLANDO
      Just got the car back from the painters this weekend..Name:  CC5DD568-986B-4DD8-898F-DADAF286C88F.jpg
Size:  344.5 KBName:  4123CC31-9BA6-4C75-A80D-A4FC40965265.jpg
Size:  177.9 KBName:  E15AA691-259F-4236-BB11-D677A73987D8.jpg
      Aug 2015
      charlotte
      what an awesome start, nothing but the fun stuff ahead
      Jan 2020
      ORLANDO
      Made some progress on the build. I picked up a LS1 today along with the corvette brake system.Name:  A62EE706-F870-4C46-B5BE-50E11C16610E.jpg
Size:  103.0 KBName:  699AA3B7-3C0D-40FC-9023-15575F752270.jpg
Size:  217.8 KBName:  2D12B030-3AD3-49E7-88ED-009CF29FE0AA.jpg
Size:  260.9 KBName:  C6E9F167-0FCE-47E8-9CEC-B515C93934BF.jpg
      Jan 2020
      ORLANDO
      It has been some time since i have updated so I thought I would share some more.
      So I found some new wheels, C5 Zo6 wheels (18x10.5 for the rear with 295's and 18x9.5 front with 275's). I think that I am probably going to change the front out to match the rear and when 295 squared on the car.
      Name:  new wheels.jpg
      Jan 2020
      ORLANDO
      Then after getting the wheels it was time to take out the rear end for refurbishment. this is the last of the old part to the car everything else was replaced or cleaned up. Also while working on the rearend thought it would be a good idea to mini-tub the car...
      Jan 2020
      ORLANDO
      After I got this all done i thought it would be a good idea to make something safer to hold the car while i worked on it. So i made some wheel boxes. this will allow me to safely get under the car to spray Raptor liner on the entire car. After that is done I will install the new 3" lower rear leaf springs, sub frame connectors and then start running the brake and fuel lines. Name:  IMG_8811.jpg
Size:  244.4 KBName:  IMG_8812.jpg
Size:  284.7 KBName:  IMG_8813.jpg
Size:  296.4 KBName:  IMG_8814.jpg
      May 2014
      Louisville, KY
      68 Camaro build
      I like the look of the Z06 wheels, did you have to use wheel spacers to get them to work?
      Jan 2020
      ORLANDO
      for the wheels I have a wheel spacer in the rear (if I remember correctly it is either 1" or 1-1/2"). Currently on the front I do not have a spacer, I think that this is only possible because of the Speedtech suspension. I still might add another spacer to the front to push the wheel further out to the edge of the fender, but that is more of a "B" priority.
      Very nicely done!!
      Jan 2020
      ORLANDO
      I have slowly made progress on the car lately and I know I have not posted for a while (it aligns with the amount of work that has taken place). The next step was to get the rear end all set up properly. I went through a lot of back and forth trying to figure out what to do (stick with Leaf springs or go with 4 link). At the end of the day, I ended up going with a 4 link (the Helix brand one).
      I did not document this too much, but I will share my opinion on it. With the low price point I knew it would not be a turn-key solution without any issues. This is a decent starting point to build from and at the end of the day I probably (maybe, if I’m lucky) will still end up under the cost of other systems out there (not counting all of my labor re-doing things).
      First off, the brackets appeared to be beefy and engineered well (they all fit as planned and lined up with the frame like they were supposed to). The Links well let’s just say I am only using the links for mock-up. For my car they are almost out of adjustment and too short in my opinion to add any force to. In addition to this the links have one fixed end and one adjustable end. This sucks my new links will have a left hand and right hand treaded ends so you can make adjustments on the car easy and correctly.
      The coil overs, well we all know they also sucks (should have bought without them), they are good mock-ups and hold the car up for rolling around the shop and with my track record that will be a little while till I hit the road anyways. Also, the Panhard bar, will the original planned location does not work well, and I had issues with this too, nothing some adjusting, and welding can’t fix, but still not an out of the box solution.
      With that all said the car sits nice and is on it’s way.
      Jan 2020
      ORLANDO
      When I first purchased the car, I came with all of the glass for the car including new windshield and rear window along with all of the trim. My plan was to always have blacked out trim (as I wanted to eliminate most of the chrome on the car), so I started on the trim. Getting it all cleaned upped, prepped and painted black. Then I had to install all of the new studs (or screws to replace the studs) from the new pane installations.
      This weekend we made a big cosmetic step and installed the glass back into the car. This was not that hard of a job, but it makes such a large mental jumpstart on the project.Name:  IMG_0005.jpg
Size:  497.1 KBName:  IMG_0003.jpg
Size:  486.3 KBName:  IMG_0008.jpg
Size:  261.9 KBName:  IMG_0009.jpg
      Jan 2020
      ORLANDO
      For the drivetrain I originally had huge plans. I wanted to have a stout LS with heads, cam and even a turbo all backed up by a Tremec TKX. As time has passed, I have realized that my dreams have out passed my budget (or what I am willing to spend on the car at this time). Since my car has sat for more than a year with little progress, I have realized that while I have been waiting for this dream to come true, I am missing out just experiencing my car and getting out there and driving it so reality has made this more of a 2 phased project.
      Phase 1 will be to install a good LS1 from a 2003 Corvette and I am going to stick with a manual transmission. So, to do this I found a good deal on Quick-time bellhousing with a LS7 flywheel and clutch. Next, I ended up getting a good Muncie 4 speed from a friend (this will keep with the sprit of the car since it was always a 4-sped car).
      So, we will begin Phase 1 shortly within the next few weeks.
      That's a great plan! I was guilty of the same thing. Scope creep will really delay a project. I'll be curious how you approach the LS and 4 speed setup.
      Mar 2021
      Indy
      Nice work! Nice Car. I hope you get it running soon!
      May 2013
      San Diego, CA
      Great job on the black out of the trim, sure blends nicely. I am considering this myself on my build. Did you scratch the paint on the trim when the windows were installed?
      Jan 2020
      ORLANDO
      The trim held up good during installation. I was originally going to powder coat the trim but I got impatient and decided jut to paint it. If it gets chips in time i will just remove and powder coat them then.
      Sep 2017
      Looking great. I'm a sucker for a white first gen.
      Jason
      TANKMASTERJ
      Jasons Toys
      2000 HD Softail
      Oct 2022
      Elm City, NC
      Thanks for the post! Looking good������ Great motivation for me. I have a 68 I started 18 years ago. My plan to to get it on the road by the end of 2023.
