    Results 1 to 1 of 1
      Nor Cal
      1968 Camaro Widebody project for sale
      Item Location (City/State): Monroe, North Carolina
      Price: $40,000 for everything or $28,000 for car and $15,000 for SB2.2 engine
      Description:
      1968 Camaro Widebody Project
      437 cubic inch SB2.2
      Dyno'd at 795 horsepower and 641 ft lbs torque
      4.170 bore x 4.0 stroke
      13:1 CR -- E85
      Dart Little M block
      Joe Gibbs SB2.2 heads ported and flowed by Curtis Boggs @ Race Flow Development
      2.18 int 1.60 exh valves
      GM SB2.2 854 intake
      BME -12cc dished piston
      Callies Magnum XL crank
      Lunati billet Pro Mod rods 6"
      Auto Verdi 5 stage oil pump
      Bullet 264/274 @ .050, .390 lobe, 1.7 rockers, 113 LSA, 109 CL
      .904 Morel lifters
      Mark Sullens 950HP E85 carb
      1-3/4" to 2" to 2-1/8" stepped Tri-Y headers into 3.5" Collectors
      All machine work and assembly performed by Mike Blackstone at Watson Racing in Concord, CA
      G-Force/Tex Racing T101A 4 speed transmission
      REM polished gears
      2.26 / 1.54 / 1.29 / 1.0 ratios
      Hurst Super Shifter
      Tilton magnesium bellhousing
      Tilton 7.25" clutch with the "Danny Popp" Quartermaster dual disc Rallye Disc package
      Howe Ford 9" housing, Ford / Roush Yates 9" center section with Detroit Locker, 3.64 gears, G-Force internal pump, REM polished gears, and #40 internal locker springs
      Jim Pettigrew (20 year Nascar / Hendrick Motorsports fabricator) built full frame and roll cage (door bar setup to be determined and finished by buyer)
      C6 Control Arms, Spindles
      LG Motorsports C6 brake cooling duct plates
      Sweet Mfg power rack and pinion
      Jim Pettigrew custom built Torque Arm
      CorteX Racing watts link
      Speedway custom Sway Bars
      Bilstein coilovers
      Hypercoil springs
      Custom built Spintech 3.5" Mufflers with rocker panel exit
      Trans Am TA2 Spec Wing
      ATL 22 gallon fuel cell (SP122B) with -10 pickup, -8 return, -6 vent
      Nascar composite carbon fiber air box
      Woodward collapsible steering column
      NASCAR 4 gallon oil tank with 20AN breather
      AP Racing pedal box with master cylinders and reservoirs
      Butler Built Sportsman full containment Halo seat
      C&R Racing radiator with dual Spal fans with integrated oil and power steering heat exchangers
      Dynotech 4" driveshaft
      AP Racing C6 brakes front/rear - AP6000S and AP6050S - 14" slotted 2 piece
      Jongbloed Racing forged wheels
      18x12 front (315 or 335 front tire)
      18x13 rear (335 or 345 rear tire)
      Currently registered in CA (2020) with refurbished original Black Plates
      More parts are included that I am forgetting to help get it to the finish line but these are the major pieces. Needs sheetmetal work finished, roof skin, door bars to your liking, oil tank and lines, radiator mounted, plumbing and wiring. All major parts are there to get it together and running. Finish flares and aesthetics how you wish.
      This is the sister car to Payton King's SB2.2 68 Camaro which is nearing completion.
      I am in CA but everything is currently located at a shop in Monroe, NC (Charlotte area).
      Feel free to ask questions here, or contact me privately to discuss further at dwgordon at gmail or 415 three one four 8 thousand.
      - - - Updated - - -
      - - - Updated - - -
      Engine
      - - - Updated - - -
      Finally, what the sister car looks like that is nearing completion (Payton King's)
      1968 Camaro widebody project
      2004 Mustang LS2
      1964 Continental
      2014 Keezer
