    Page 2 of 2 FirstFirst 1 2
    Results 21 to 24 of 24
    1. #21
      Nov 2011
      Wylie, Texas
      Other electrical components like the cooling fans actually don't matter much when it comes to sizing the starter wire size. The current from these components are just a fraction of what the starter is going to use during cranking plus it's the alternator that will be providing the majority if not all the current for these devices.
      I thought you guys might like this. I plotted a graph of my engine starting. Just for fun I connected my meter directly to the battery posts and across the negative battery cable which is only about 12 inches long. This way I can monitor the battery voltage and the battery current simultaneously. I'm using the negative battery cable as a resistor shunt much like the car's amp meter does.
      I have a trunk mounted battery using 1/0 gauge wire and my engine is a LSA which has 9.1 compression ratio and the starter is a Summit branded LS starter. As you can see in the graph my battery voltage (blue line) dropped to around 10.7V during cranking. You can also see how the alternator starts producing power as the battery voltage rises to around 14V and the current (red line) to the battery reverses (starts at 0V then up to 0.13V then back down to -0.005V to charge the battery).
      To answer the original question, my opinion is that 1 gauge wire will also work fine.
    2. #22
      Quote Originally Posted by blitzer454 View Post
      Awesome. Way to bring it....
    3. #23
      May 2019
      Pensacola,Fl.
      Size for size, marine cable won't handle more amperage than it's non marine counterpart or so much so that it's really measurable. The value in marine is that there won't be corrosion issues.
      Not exactly.....Marine cable is AWG....If your comparing the same gauge & AWG cable then I agree.....But....If you compare it to the same gauge and SAE cable then No. The SAE cable is stiffer.....Why is it stiffer? Because it has larger wires in its make up. Now Current travels on the outside of each wire....Smaller wires but more of them will handle a larger amount of current at the same gauge. So AWG is more flexible and it will handle more current than SAE. Marine cable is not only tinned...But it has a Much better insulation on it.....I buy a LOT of it in rewiring boats.
    4. #24
      Quote Originally Posted by Warthog5 View Post
      I am guessing the “skin effect” is negligible for battery cables. Pretty sure it doesn’t occur with DC...
      Skin effect here:
      https://circuitglobe.com/skin-effect.html
