    Results 21 to 40 of 53
    1. #21
      Jan 2013
      ST George UT
Size:  143.1 KBName:  IMG_1290.jpg
      Finally got some time to start building the exhaust.
    2. #22
      Jan 2013
      ST George UT
      One side is all the way out the back.
      Took some time. All mandrel bent 2.5”.
Size:  435.7 KBAttachment 176160Attachment 176161
    3. #23
      May 2011
      Nice build ! Is that Magnaflows exhaust kit for our impalas? What size tires and wheels are you running on the back ?
      Andy
    4. #24
      Jan 2013
      ST George UT
      Thank you.
      The exhaust started out as Magnaflow exhaust kit, I had to buy 6 extra 90 deg and a couple of 45's and cut and make changes.
      A couple extra hangers.
      Rear rims and tires are 20x11's with 295-30-20. I did narrow the rear end 2" each side.
    5. #25
      May 2011
      Thank You !
    6. #26
      Jan 2013
      ST George UT
      Rear brakes and exhaust all done. Now back to finishing out the trunk close out panels, then finish power windows and interior.
    7. #27
      Jan 2013
      ST George UT
      Trunk is finally done.
      Now on to interior
Size:  421.2 KBName:  IMG_1429.JPG
    8. #28
      Orange County, CA
      Man I love this car, great job
    9. #29
      Jan 2013
      ST George UT
      At alignment shop now.
      Getting close. Name:  IMG_1496.JPG
Size:  615.0 KBName:  IMG_1492.JPG
Size:  605.9 KBName:  IMG_1493.JPG
    10. #30
      Aug 2002
      Waleska Ga.
      Beautiful car !
      Excellent choices
      David Sloan
    11. #31
      May 2011
      Quote Originally Posted by classiccarcustoms View Post
      Powder coated the frame.
      Complete front and rear ridetech coil kit showed up from Santa 🎅
      Also added an extra adjustable upper trailing arm.
      -Global West upper rear shock brace crossmember.
      -Global West left and right frame supports.
      -Global West panhard bar drop down centering bracket.
      Hope to get Baer brakes this week.
      Engine and transmission installed this week.
      what ride tech kit did you use in the rear ?
    12. #32
      May 2011
      Quote Originally Posted by droptop62ss View Post
      Never mind I found it !
    13. #33
      Jan 2013
      ST George UT
      I founds some nice low back power bucket seats and made brackets to bolt into factory location. Now build a center console and then off to interior shop. Name:  61552516041__CA5EC01D-8D36-470F-96C1-EB703F16E4C2.jpg
Size:  154.9 KBAttachment 177393
    14. #34
      Sep 2017
      What a beautiful, sexy build! If I had my choice of super models or this fine ride, I WANT THE CAR!!! Absolutely beautiful Bubble top!!!
    15. #35
      Feb 2019
      Kankakee IL
      Great car.
      If I can ask a couple of questions...
      When you added the second upper trailing arm on the rear did you have to fabricate a bracket or did you simply aquire a second OEM on and bolt it on the chassis?
      Second, who makes the billet hood hinges?
      Thanks.
      I have a 60 wagon and you thread is inspiring.
      Tracey
    16. #36
      Jan 2013
      ST George UT
      Adding 2nd rear upper trailing arm: I had to drill holes in frame and installed a bracket supplied by Ride Tech as far as the rear end side, I had to weld on a bracket to housing supplied by Ride Tech.
      Eddie Motor Sport billet hood hinges. FYI They don't fit good at all. Looks great but at their lowest setting the hood sits up at least 3/8" at the wiper cowl. Sat perfect with stock hinges.
      I have pictures and measurements into Eddie Motors sports. If I don't hear anything I will modify them to fix that gap, but at $600 I shouldn't have to.
      Or take them off and throw them away and make a set.
      Just finished the interior, here are some pictures
    17. #37
      Jan 2013
      ST George UT
      She drives great. Got 400 miles on her.
      Now I want more. When I built the LS2 I built it for boost. So New Currie 9" ordered.
      Also ordered Edelbrock super charger. Both should be here this week.
      Some current pictures of under the car, before out with the old.
    18. #38
      Sep 2019
      Incredible car
    19. #39
      Sep 2020
      Louisiana
      Outstanding build!! What are those bucket seats out of? Looking for something for my 62 that has a low back and not overly shaped so still looks like it belongs. Also, how difficult was it to fab up brackets? I have not had the bench out yet to see how flat the floor is and what I’ll ha e to work with. Thanks in advance!
    20. #40
      Jan 2013
      ST George UT
      Thank you.
      Front seat are out a 1996 Toyota Avalon. They fit great. Perfect size.
      Mounting them, i used all the factory spots on the Impala and factory brackets from Toyota. I welded 3/8 metal plates to the floor at the factory seat location with nuts welded in, so they bolt right into the factory floor. I can see if I have picture.
      Do not get the Avalon seats with memory......
      I also have these seats now in my chevelle and 55 bel air.
