Results 1 to 1 of 1
12-18-2019 #1
68 Camaro Help with 18" wheels CCW classics
hey guys, i've finally decided which wheels I like most, CCW Classics, and should be ready in a couple of months to place an order. I was hoping on getting some advice on wheel & tire sizes for my 68 Camaro. I'm planning to go with 18" wheels.
My current setup: for reference to help with new setup sizing
Wheels: 17x8 , 4.5 backspace, 0mm offset
Bolt Pattern: 5x120.65
Tires: 235/45/17 & 245/45/17
Disc/Rotor size: Unknown, it came with the car (photo below)
Suspension: ridetech streetgrip, however dealing with ride height issues atm, and working on adjusting that. Right now, the front is lowered way more than rear and is rubbing. I've ordered 3/8" coil spacers that should lift by 3/4" hoping. The Rears: space between fender in tire is about 2.4", I've ordered a 1" lowering block, and hopefully that should leave me with about 1-1.4" space.
Below is how it sits now (still waiting on the coil spacers & lowering block)
Questions
1) Max width I can go with (front & back) for 18"? (note: I like a deep dish style, neg offsets)
2) Bolt Pattern? (they come in: 5x100mm through 5x130mm and in 6X4.5 and 6x5)
3) Max tire width (front & back) without rubbing? (note: my suspension details above)
Did a crappy photoshop below showing 2 options (top: Black Matte center/Gloss lip , Bottom: full gloss)
Thank you in advance : )
1968 Camaro SS | LSx 364ci
T-56 | RT StreetGrip | RT Steering Kit | TRSD Disc Brakes | Wilwood Dual Piston
Tags for this Thread
