    Results 1 to 17 of 17
      Feb 2011
      Best wheel and tire size for a 66 Chevelle
      Hey guys. I have a 66 Chevelle Pro Touring build. I am running 18s front and 20s rear right now and I'm thinking about changing. What do you think is the ideal wheel and tire size for aesthetics as well as function? Thanks
      Fredericksburg, VA.
      18s front and rear!
      Steve Hayes
      "Dust Off"
      68 Camaro
      May 2018
      way east on a rock
      Call me biased, but I kinda like 18's all around. Fronts are 9" , will be 275's when I'm done, currently 255.Rears are 335/35/18 on 12" rims
      Oct 2018
      San Jose, CA
      I agree. 19-20” doesn’t look right on a chevelle or Camaro IMO.
      18”. 245/275 or whatever fits. I run 275/295 on my second gen Camaro on 18x10s.
      1971 Camaro - 406 / T56
      2016 Camaro SS convertible
      2018 Colorado 4x4
      Mesa, Az
      I like the look!! What are the specs on these wheels and tires???
      -Paul
      1969 Camaro "Reckn8"- LS7/C4 Front and Rear
      1965 Oldsmobile F/85 LS6 W/Maggie, 6-speed,Ride Tech, Baer brakes
      1978 Blazer 2 wheel drive with LS power
      1965 VW bug. All original
      1968 GMC short box
      1964 Buick Riviera
      Oct 2015
      235/45 & 275/40 18’s
      Oct 2015
      Front view
      Oct 2006
      14" look best. If only you could find tires like we used to have.. 15" are the best looking. Those big wheels are out of scale on these older cars..
      On my 69 el Camino I have the SC&C Stage 3, Lee 14:1 with Spohn delsphere control arms in the back and the handling is amazing using plain old 225/70r15 Cooper Cobras..
      I am using Porterfield pads and brake shoes with the stock disc/drum set up and it stops good enough for me..
      Feb 2011
      How was the fit?
      Hi. Did those fit without any modifications? I like those sizes.
      Dec 2016
      hey jim. just curious the back spacing you figured out for the wheels and whether you had to modify the frame to keep the 10' and wider tires on rear from rubbing? thks .
      Oct 2015
      Kansas
      [QUOTE=magic32;1318475]Hi. Did those fit without any modifications? I like those sizes.[/QUOTE
      Other than rolling the rear fender lips, yes. The 295s are a very tight fit though.
      Quote Originally Posted by Brentnicolson View Post
      Im not Jim, but im guessing you're asking me. The rear backspacing is 5.00" BUT My rearend is narrower than a stock 67 a-body, so my rear backspacing is unique to this car. The 10" wheel and 295 is a pretty tight fit. In my opinion, fitting this size requires wheel lips mods, and a wheel fitment tool to make sure you are getting it exactly right. The backspacing on the fronts are 4.75" Hope this helps.
      Orange County, CA
      I went with 19’s and 20’s on my 65. Maybe 18’s would handle a little better, but I don’t track the car. I like the way the wheels fill out the wheel wells.
      Oct 2022
      Hey ShelteredChevelle
      Hey ShelteredChevelle?
      Great set up with those wheels and tires.
      What offset/backspacing are you using?
      May 2018
      way east on a rock
      Thanks. This is the finished car. I went with A.R. VNCL405- 18 x 8.5 w/ 4.5 BS Front 18 x 12 w/4" BS rear. My rear housing is 56" wide. 335/30-18 & 265/60-18
      Aug 2021
      Looks very nice, I looking for a 66 or 67. If you know of any let me know
      Nov 2022
      Apr 2023
      Is your car mini tubbed? It looks great. What is the rear wheel backspace
