      Aug 2012
      1969 Resto Mod Firebird LS3-T56
      1969 Firebird Pro-touring LS3 6-speed - $68,000 - Farmington, NM
      As much as I love my car, things change in life and I must sell it. 1969 Firebird with ground up restoration no expense spared on upgrades. Car has the old school body but new car handling. Drives like it is on rails. I have driven it in cross country rally since completion and it did not disappoint in performance. I have hundreds of build pictures and documented much of the process. The ’69 Firebird was already a unique car and this one stands out from all the rest. I have listed the major upgrades and there are many others I am sure I have forgotten. Upgraded to an LS3 from LS2 after rally. LS3 has less than 500 miles. Recent dynotune with 488 rwhp and 465 ft-lbs. The interior is not completed behind front seats, has sub box in place of back seat and needs close out panels made, or I could remove box and make some simple panels.
      Body:
      Shaved Drip rails
      Flushed rear bumper
      One piece front end
      Sail panel fuel filler
      Welded seams
      Functional heat extractors in fenders
      Stainless grill inserts
      Trans-am spoilers
      Debadged-antenna delete
      Smoothed firewall
      Inset rear plate
      Flush mount Fesler Glass
      Flush mount door handles
      Gen2 mirrors
      Billet hood and trunk hinges
      Chassis and Suspension:
      DSE subframe conectors
      Speedtech Chicane coil over shock mounts
      Notched subframe for low mount A/c and Alternator
      ridetech Select Coil-overs all around, electronic dampening
      BMR A-arms
      AFX tall spindles
      BMR 1.25” front sway bar
      BMR rear torque arm w/ watt’s link
      Aluminum body bushings
      Engine:
      Blue printed New LS3 aluminum block Gen IV
      King racing chamfered main bearings
      King racing narrowed rod bearings
      GMPP cam bearing set
      Callies Compstar Forged Crank 4.00" Stroke
      Callies Compstar Forged H-Beam 6.125 ARP2000
      This short block is rated to 900HP
      ARP MAIN STUDS
      GM LS9 heads
      CNC PORT LS9 heads
      PAC Dual springs good to .660" with Titanium Retainers
      FERREA Stainless Intake and Exhaust Valves
      Thompson Motorsports custom ground Camshaft 240/256 .625" .625" @1.7 113+4.662" .662" @1.8 ratio
      Thompson Motorsports custom length Chromoly pushrods
      ARP Head Studs
      Melling Select High pressure oil pump
      FAST 102mm Intake
      Holley Fuel rails
      Drivetrain:
      T56 6 speed
      Tick Master cylinder hydraulic clutch
      Monster Clutch twin disc with lightweight SFI flywheel
      Strange 9” rear axle with 3.76 gears
      Custom length driveline with 1350 u-joints
      Brakes:
      Wilwood 14” 6 piston front brakes
      Wilwood 13” 4 piston rear brakes
      Drilled and slotted rotors, front and rear
      Wilwood Master cylinder and adjustable proportioning valve
      Tire and Wheels:
      Billet Specialties Grand Prix 18x8 front, 18x11 rear
      Pilot Sport Cup 2 tires
      Interior and Electronics:
      Dash and center console out of 2005 GTO
      TMI microsuede one piece headliner
      TMI door panels
      Dynamat on floors roof and doors
      Pioneer AVIC-8200NEX navigation with 7” touchscreen and backup camera
      6 Rockford Fosgate speakers
      Has subwoofer box in place of rear seat, I can remove and make interior panels instead
      Keyless entry with electronic trunk latch
      Trunk mount optima battery
      LED taillights
      Dapper lighting projection head lights with halos
      HVAC system out of 2005 GTO
Size:  306.6 KBName:  IMG_0227.jpg
Size:  208.7 KBName:  IMG_0232.jpg
Size:  224.0 KBName:  Undercarriage.jpg
Size:  111.3 KBName:  Subframe.jpg
Size:  78.1 KBName:  Shock tower.jpg
Size:  67.3 KBName:  Firebird emblem.jpg
Size:  106.6 KBName:  IMG_E0227.JPG
Size:  247.8 KBName:  BVUH4573.JPG
Size:  43.4 KBName:  IMG_0257.jpg
Size:  338.8 KBName:  20180422_130526.jpg
Size:  190.8 KBName:  20180427_180159.jpg
Size:  228.3 KBName:  IMG_0939.jpg
Size:  132.0 KBName:  IMG_0941.jpg
Size:  193.9 KBName:  IMG_0938.jpg
Size:  232.0 KBName:  IMG_0940.jpg
      Daniel
      1969 Firebird LS3/T56
      Build Thread: https://www.pro-touring.com/threads/...quot?highlight=
      Feb 2011
      Wow, As a 1st Gen Firebird Fan, this looks fantastic. A lot of work here. GLWS.
      Nov 2007
      PM sent contact info
      Outstanding! Sorry you have to let it go.
      Oct 2013
      H-Town, TX
      I’m not usually a fan of PT 69 birds but my god this car is beautiful!!
      May 2009
      Wow, what an amazing car! I have also have a 69 FB and love the look of the painted to match from bumper. I think it makes the car look like a baby 70 GTO. Good luck with the sale.
      Feb 2019
      What an awesome Firebird!
      1968 Skylark - 462, TKO 600, RideTech, CPP
      1989 Mustang - 351, Vortech V3
