    Results 1 to 10 of 10
      Jun 2010
      Deployed
      Gm 12662757 starter for Z28
      Does anyone have a clue why this GM starters application is only for the 2014-15 LS7 Z28 Camaro? Seems odd to me....
      1970 Camaro/DSE build
      Jun 2010
      Deployed
      Same starter used on the new LT1. It’s smaller and has a different connector for the solenoid which would explain why it’s not compatible with earlier LS applications.
      Jun 2010
      Deployed
      Here’s the difference. Might be a worth while y
      typical LS1 starter upgrade.
      Jan 2014
      Portsmouth NH
      Thanks for the info. My question would be will it fit in the Quick Time Bell Housing. https://www.holley.com/products/driv.../parts/RM-8020
      Jun 2010
      Deployed
      as soon as I get my new bolts, I’ll find out. I have a LS7 with the QuickTime. Right now I see no reason why it wouldn’t.
      Quote Originally Posted by Motobrewmaster View Post
      Jun 2010
      Deployed
      installed it today, no issues. Waiting on my heat shield to connect the wires and ensure it all works harmoniously
      NJ
      Nice, look at that, smaller and more compact!
      Jun 2010
      Deployed
      Quote Originally Posted by John McIntire View Post
      Works great, sounds like it has more power. But that may because my old starter was not in good health
      Jan 2014
      Portsmouth NH
      Great info about the fit for your starter. I will consider one of these in the future when mine dies. I had to take some material off my Quick Time bell housing and the starter to get them to fit. I am using the GM 28-12617229 - LS3 Starter and it would have not fit without the clearancing.) Not sure what the reasoning for it not fitting maybe it is my combination i.e. LSA block with the Quick Time housing.
      Jun 2010
      Deployed
      Must be something about that starter. The starter that was on my LS1 was a standard LS starter. I moved it over to the the LS7 and no issues and now this smaller Z28 starter with no issues. All three applications were using a Quicktime Bellhousing.
