    Results 1 to 20 of 36
      Sep 2018
      Sandy OR
      Dry Sump Tank Help
      I am dry sumping a crate LS7 in my 68 Camaro. Engine is installed and I am looking for thoughts and ideas for sump tank construction and location. To this point I have a clean, flat firewall installed and want to keep it that way. Considering locating tank where in the stock battery location. Any thoughts, ideas, or comments are appreciated.
      I located a customer's tank (69 Camaro, LS9 engine, see my signature for pics) in the passenger side hollow behind the front tire/in front of the rocker panel. Stef's Fabrication made me a custom tank that fit the area quite nicely.
      John Parsons
      Pensacola, FL
      That's a nice setup. If I realized it could have been done like that I would have liked to have kept the dry sump.
      Jun 2010
      Deployed
      Mines located where the battery was on my 70 Camaro. I have seen people mount square tanks on the firewall and normal tanks inside the cowl (body fabrication required). I believe Peterson does have a specific 1st gen camaro tank for the battery area.
      If you don’t use a narrow/tall tank, youre not going to get the intent of the dry sump.
      1970 Camaro/DSE build
      Jun 2010
      Deployed
      Here’s mine, same concept for a 69
      Feb 2019
      Kankakee IL
      Tuck it up under the back half of the front fender.
      Tracey
      Jun 2010
      Deployed
      Quote Originally Posted by Tsaints1115 View Post
      Not as much room as you would think. I feel inside the cowl is a perfect spot! Maybe one day, that’s where mine will be going. Cris @ JCG has done it and I like it.
      Chicago suburbs
      I really like that tank setup that John posted. Just when you think everything has been done to these cars, that's really unique & really seems like it may just be the best solution for a dry sump tank. Nicely done!!
      Jun 2010
      Deployed
      Quote Originally Posted by another69 View Post
      The location is where I want mine to be as well. Why go with a square tank though?
      I do disagree that's the "best solution"...there are better tanks and alot of first gens have the tank where it is on my sec gen
      https://www.lateral-g.net/tech_articles/LS7_install/
      My customer's tank has an internal swirl chamber (the main reason for a cylindrical tank) and trap door access to the nooks and crannies once it's made its way through the swirl chamber. It allows for more oil volume since all the space is being utilized.
      If a cylindrical tank can fit there and provide adequate volume, then that'll be a less-expensive solution for sure.
      John Parsons
      Mar 2013
      Napier, New Zealand
      Country Flag: New Zealand
      Peterson ls7 tanks
      I put mine opposite side of battery and hung breather off it.
      Breather has a drain hose attached.
      Required modifying fender, i also extended the fender down to protect tank from stones off front tyre.
      Best thing is it gets great natural cooling on the tank.
      See also I modified ls7 oil pan to have lines coming off the front
Size:  64.8 KBName:  11025796_10204997852000668_2665590089048524376_n.jpg
Size:  40.5 KBName:  14102283_10208779595341888_7030706444640034559_n.jpg
      Damien
      Napier, New Zealand
      Project Page: https://www.pro-touring.com/showthread.php?99096-Project-Camaro-68-P-T-Muscle
      Next Project: 1956 Chevy Truck, Full C3 Suspension, Nascar Inspired
      Sep 2018
      Sandy OR
      Thanks Tweak,
      Couple questions;
      - Can you provide the Peterson part numbers you used
      - Love your cold air intake, did you fab that? More info or pictures much appreciated
      Thanks again, Will
      Jun 2010
      Deployed
      Quote Originally Posted by willt View Post
      Thanks Tweak,
      Couple questions;
      Thanks again, Will
      Get them to make you a tank with a threaded cap. Not the generic twist cap...
      Mar 2013
      Napier, New Zealand
      Thanks Tweak,
      Couple questions;
      Thanks again, Will
      Hey
      Oil tank http://www.petersonfluidsys.com/drys...ecial-LS7.html
      Breather http://www.petersonfluidsys.com/breathercan-LS7.html
      Yes, I 3d printed it from ABS plastic and fitted a K&N Mercedes Filter
      It used to have a maf sensor, but my tuner thought the cam was causing issues, so he tuned it mafless. Its just has air temp now.
      Damien
      Napier, New Zealand
      California
      How does it draw in air with the radiator there?
      The model looks like it basically sits on top of the radiator.
      Looks absolutely bitchin, though.
      Matt
      Mar 2013
      Napier, New Zealand
      Rad leaned back
      Quote Originally Posted by DarkoNova View Post
      Rad leaned back
      View from underneith
      Damien
      Napier, New Zealand
      Hildebran, NC
      Awesome Intake!!!!
      California
      Wow, that's awesome.
      Nice work!
      Matt
      Sep 2018
      Sandy OR
      Tweak, that intake is friggin amazing! Thanks for the tank info.
      Sep 2017
      What oil pan did you use? The stock LS7?
      Modify it?
      I just pulled the trigger on an LS7 with Late Model Racecraft 630hp kit.
      I got to figure out how to make it happen.
      Tank was damaged in wreck. So I need a Peterson tank and some kind of oil pan
      Jason
      TANKMASTERJ
      Jasons Toys
      2000 HD Softail
    Tags for this Thread
