    Results 1 to 20 of 25
      Apr 2008
      Ohio
      Best affordable brakes for second gen firebird with afx spindles
      Hello all! I am working on my 71 Firebird Pro Touring build and am in the process of putting the front subframe together with SpeedTech suspension. I am at the point of needing brakes for the AFX C5/C6 spindles. I’m not really looking to spend 5k on brakes....I wish I could. Lol.
      I am looking at the Powerstop/Stop Tech option but looking for other options as well. I am also unclear as to what options to order as the Corvette brakes have several....just not sure what will fit the AFX spindles. Anyone with experience with these spindles and choosing brakes? Thanks in advance!
      El Paso, Texas
      Pretty much anything Corvette 97-up will fit it, IIRC. First option is the standard (JL9) 12.6" rotor with C5/C6 calipers and regular abutments(brackets), next is the Z51 (J55) rotor at 13.6" with C5/C6 calipers with Z51 abutments, and finally the big dog, Z06 (J56) rotors at 14.6" with the 6 piston calipers. I don't know about the J57 15.5" option but from what I see on pricing all I can say is YIKES!. Rockauto is your best bet for pricing. Here's a couple of links that go through the brake options for standard Vette's. I use the 13.6" on my Chevelle with an LS3 and hydroboost and it stops just fine. Real easy to lock up. HTH.
      Alex
      https://www.corvetteforum.com/forums...55-brakes.html
      https://vettelab.com/news-projects/e...-option-codes/
      Apr 2008
      Ohio
      Yikes was my reaction as well!! Lol!! Thanks Alex!
      Apr 2008
      Ohio
      Great information!
      Oct 2018
      San Jose, CA
      Kore3 also sells the C6 brakes as a bundle for that spindle if you don’t want to piece it all together. Their pricing is pretty fair.
      1971 Camaro - 406 / T56
      2016 Camaro SS convertible
      2018 Colorado 4x4
      Apr 2008
      Ohio
      Are the Kore3 brakes better than the ones you get from RockAuto?
      Oct 2018
      San Jose, CA
      No. They are stock corvette. But it’s sometimes hard to find the abutement plates and Kore3 includes those in the kit.
      2018 Colorado 4x4
      Apr 2008
      Ohio
      They probably don’t sell them separately either.
      Oct 2018
      San Jose, CA
      What do you want separately ? Call them they might.
      This is the kit they sell for those spindles ;
      http://kore3.com/proddetail.php?prod=10336-01
      2018 Colorado 4x4
      Apr 2008
      Ohio
      Abutement plates. RockAuto has the front and rear as a kit for $700+....which is a decent deal but I’m sure it doesn’t come with said brackets to adapt to a 9”. I’m gonna give them a call to see if I can just buy the brackets.
      Oct 2018
      San Jose, CA
      They should sell brackets separately. Abutement plates depends how they source them. If they get as a kit with calipers they wouldn’t separate. These things are hard to find. All the kits assume you have them.
      2018 Colorado 4x4
      Apr 2008
      Ohio
      I appreciate all the info c4racer2!
      Mar 2004
      Mid-Michigan
      I got all of the Corvette stuff I am using on BadAst off eBay. The red set I used for development was a couple hundred. The black set I am actually using was about the same price and they are brand new. I got new abutments from Schram Auto Parts along with slide bolts and all of the fasteners. With everything I purchased I have about 700 into the everything and will be selling the red ones to recoup some cost.
      I used Kore3 brackets on the 9". They fit very well and will do the job.
      Check out my build thread:
      https://www.pro-touring.com/threads/...Faze-II/page21
      I put the brakes together on pg. 21 and go thru some of the clean up and paint work as well.
      Mark
      Mark:
      This my Bad Ast thread...
      This is my Fotki album...
      http://astroracer.fotki.com/
      Apr 2008
      Ohio
      Thanks Mark!
      May 2015
      Island Lake, IL
      Not cheap but if you want Wilwood, look into the Wilwood SLC56 (C5/C6) calipers...
      https://www.summitracing.com/parts/wil-140-15173-r/
      Other than that, the best affordable setup is standard GM rotors/calipers. Your best investment is good pads.
      Apr 2008
      Ohio
      Thanks F-Body International
      Dec 2010
      Fredericksburg, VA.
      A lot of the Corvette guys take off the stock brakes and install something else/better. I found a full set of C6Z06 calipers virtually new for around $450 without rotors.
      I had to fabricate the rear caliper brackets but I hear Kore3 now offers everything you need in a kit using the stock C6Z06 calipers. I had to order custom rotors for the rear due to installing them on a Moser floater rear axle. The correct pads will make all the difference between a brake system that works well and one that doesn't. I have experimented with numerious different grip level pads before settling on a high grip pad up front and a lower grip pad on the rear in order to get the balance dialed in.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Given sufficient initial acceleration, even pigs can fly!
      Apr 2008
      Ohio
      Very nice!!
      TuoCo, CA
      check ebay for the abutment brackets too. I got my rears there. Some of the rock auto kits include the abutment brackets.
      Steve
      Check it Out Here
      Jan 2020
      ORLANDO
      There is nothing wrong with he standard C5/c6 brakes. We run these on our corvette C4 race car running close to 160 mph at Daytona. I just picked up a set of takeoffs from a 02 corvette (calipers, rotors, master cylinder, and booster for $300. I plan on using them on my 68 Camaro with AFX spindles.
