    Results 1 to 3 of 3
      Wisconsin
      DSE Subframe trans crossmember
      First Gen Camaro with DSE front sub, LS motor, T-56 mag trans...... what cross member are peple using? I planned on using DSE engine/motor mounts (1.5" set back), and want to use a crossmember that will keep the driveline angle correct....
      TIA
      Used to be known as classiccamaro
      Hildebran, NC
      I thought I remembered a post about this earlier...
      https://www.pro-touring.com/threads/...um-Crossmember
      Fredericksburg, VA.
      I actually ended up building my own trans cross member after trying three different store bought ones. Thank goodness Summit was cool about me sending them all back.
      Steve Hayes
      "Dust Off"
      68 Camaro
