      California
      1971-1972 Pontaic Lemans/GTO fenders wanted
      I am looking for a fender for my project, I need a pass side fender for a 1972 Pontiac Lemans/GTO. 71 and 72 will interchange, but there are small differences. 70 will not interchange, however, I may be able to use a 70 fender as a donor. If I can confirm that the area above the wheel is the same I could use a 70 fender as a donor and piecemeal a good fender from two. Below is a picture of what I have to work with. I can get a patch for the bottom rear area, but I hate to even attempt to make a patch for the area above the wheel. If you have something that may work, just let me know. There were a few on Ebay, but the crack smokers on there want 2900.00 each side for a used fender.
      Aug 2019
      Nashville, TN
      I may have a couple of ‘70 GTO front fenders and nose. I realize that year is not ideal for you, but let me see what I have. Parts are about an hour away, so I may have a chance to check in a week or so.
      Oct 2013
      H-Town, TX
      You should be able to use a 70-72 LeMans or GTO fender for parts- mounting points should be the same but only the 72 with the endura option will have the air extractor in the fender.
      Jun 2019
      70 gto
      Would these work? These are for a 1970 gto. The basic shape looks the same but marker lights are different.
      https://www.opgi.com/sheet-metal-bod...o-g240141.html
      California
      I was able to find a 1970 GTO fender to use as a donor, I am going to have to do a lot of cutting and splicing. It is still easier than paying some a$$hat 3,000 each side.
