11-14-2019 #1
C5 brake components for 1st gen Camaro
I've heard that the CPP C5 brake kits don't have the best components. I'm trying to do something similar and upgrade the parts. Is it possible to piece together decent parts without braking the bank? I found a Power Stop rotor, pad, and caliper kit (https://www.autozone.com/brake-syste..._347103_0_2805). I think the calipers are stock twin pistol Corvette, complete with the logo. Can I just add Kore3's brake lines and brackets to complete this kit? Is there anything else I would need to buy? Are there better options for around the same price? I can get that kit by searching around for somewhere in the $300's. I have 17" wheels and will check the template before I buy. Thanks for the help.
1968 Camaro, 383 with Dart Pro 1 aluminum heads and roller cam, 4-speed Muncie, 4.11 12-bolt differential.
11-15-2019 #2Registered User- Join Date
- Aug 2007
- 645
I've used C5 brake parts many times. I'd check over on Corvette Forum for some used stuff. Rock auto is another source. Chain stores and Rock Auto will want cores. I've had good luck with NAPA stuff. Make sure what ever you buy the calipers come with the caliper brackets. They are about as expensive as the calipers.
If you buy used C5 calipers rebuild kits are pretty cheap. Just make all threads are in good shape. I bought my brake hoses from KORE3. Rotors and pads from Summit.
11-17-2019 #3Registered User- Join Date
- Feb 2016
- Texas
- 93
