    Page 5 of 10 FirstFirst 1 2 3 4 5 6 7 8 9 10 LastLast
    Results 81 to 100 of 194
    1. #81
      Chicago
      Quote Originally Posted by JayinMI View Post
      Marty, that's saying something because Syborg was no slouch either. Shame the build pics all seem to be missing.
      I really do enjoy these videos. This truck is coming out very well.
      Jay
      Hi Jay and thank you and goodnews the build pics are still up on http://syborgtwinturbo.com/pictures/ and one day I will go back and link all of the pictures in the thread. Right now I am working on 2nd chance pictures and holy crud is that taking a long time.
      Keep building and posting pics and video's as I think we all are enjoying the build.
      mj
      marty-mj
    2. #82
      Jun 2019
      Talk about an incredible project.
      You sir are my idol and I can't tell you how much I look forward to your next video and post.
      Thank you very much. Originally when i started thinking about this, I was going to back half my truck and put a 9" under it and go for a boosted LS. This escalated quickly lol.
    3. #83
      Chicago
      Quote Originally Posted by loudandproud View Post
      That happens sometimes, well at least it happens to us car guys.
      marty-mj
    4. #84
      Jun 2019
      Well I started on something different last week. The chassis is coming along nicely, so we will soon be placing the cab. Once the cab is on, we need to place the motor. In order to place the motor, I need an oil pan. I decided a while back that I will be going with a 5 Stage dry sump setup on this project. 4 Scavenge stages, one pressure stage. There will be 3 scavenge stages to the pan, and one scavenge stage dedicated to the turbo drains. Having a dry sump allows me alot of options.
      1. Better oil control, wont run the sump dry on hard 60ft hits
      2. Short profile oil pan that allows the engine to sit 3" lower (better CG)
      3. Higher Oil capacity (2.5 Gallons)
      4. You can now low mount turbos because you can directly scavenge the oil to the tank. (Better CG)
      LTx dry sump oil pans are currently all made by very high end manufactures. Most are billet and $1200+. Soooo. I made on.
      3/16" Steel Flange
      16" Pan
      -12 AN Scavenge ports
      I plan on running inline scavenge filters to protect the pump.
      Ill need to get the inside of the pan blasted with walnut or something to remove the chances of any scale popping loose and hurting the oil pump.
    5. #85
      Jun 2019
      Here is the video of the pan build. Thanks for viewing.
    6. #86
      Jun 2019
      I got my front sway bar setup installed. It's a speedway engineering setup. 1.25" x .250w" bar, 33" long. Using their steel arms. As you can see in the video... they weren't perfectly plug and play for my mounting style. The center of the bar was over sized so I could not pass them through the bearing. I ended up turning them down. Now everything is mounted up and working great. My buddy Logan bent up the arms for me on his 400T press.Name:  20200512_172219.jpg
Size:  100.8 KBName:  20200516_175536.jpg
Size:  125.3 KBName:  20200516_174416.jpg
Size:  157.8 KBName:  IMG_20200517_182955_216.jpg
Size:  81.1 KBName:  20200517_181546.jpg
    7. #87
      Chicago
      Great update and as always can't wait for more.
      Tonight I hope to watch some of the video's
      marty-mj
    8. #88
      Jun 2019
      Teaser pic of whats to come...
      Any one know what this is?
    9. #89
      Feb 2014
      Looks like one of those old school turbo encabulators to me. Very cool.
    10. #90
      Jun 2019
      Quote Originally Posted by Bob in St. Louis View Post
      It came with a red powerband too
    11. #91
      Feb 2014
      Epic!!!
      haha!
    12. #92
      Jun 2020
      looks like a Guibo. Is that an overdrive or 1:1?
      BTW, Andrew turned me on to your build. Really like it.
    13. #93
      Jun 2019
      Quote Originally Posted by DblTrbl View Post
      Thanks alot! This is a S65 V8 configured DCT, so it will be the 1:1 7th gear.
      Looking at running a 2.85 rear gear with a 335/30/19 rear tire.
    14. #94
      I really like the 1:1 top gear. It should be very quiet, plus having a high rear end gear will keep the driveshaft RPM way down.
      Instagram @projectgattago
      Dr. EFI
    15. #95
      Jun 2020
      I started a thread in the Manual Transmission section you may be interested in.
      https://www.pro-touring.com/threads/...smission-(DCT)
    16. #96
      Jun 2019
      Got the front coilover mounts on the chassis welded in. They have flanges at the top that will tie into the from cage assembly. Happy with how the turned out.
      Also made the tie rod adapters for the front end. Should be plenty beefy.
    17. #97
      Jun 2019
      https://youtu.be/O9pJejZ76GA
      Episode 18 of the build is up. Thanks for watching and commenting.
    18. #98
      Just watched it today! Good stuff. I'm totally going down the DCT rabbit hole! It would be awesome to make it work in my Cougar.
      Dr. EFI
    19. #99
      Jun 2019
      Ill keep you posted. I placed an order for the Domiworks Engineering Billet adapter. Thing looks like a jewel... and it will be hidden under the truck. Figures lol
    20. #100
      Aug 2002
      Waleska Ga.
      cool build !
      Love the videos
      David Sloan
