    Page 4 of 9 FirstFirst 1 2 3 4 5 6 7 8 9 LastLast
    Results 61 to 80 of 178
    1. #61
      Benicia, Ca.
      Quote Originally Posted by majj35 View Post
      Got it, so ill add the top clamp plate i have, and then get a 1” lowering block for a multi leaf
      Thanks guys
      Sorry I am little late to the party but yes, a lowing block out back will let you dial in ride height, within reason..
      It does sound like the shop slipped with the ball joints, not knowing they were tall's.
      I think those two items will have you all dialed in.
      Thanks,
      Matt
      MCB - Matt's Classic Bowties
      5360 Gateway Plaza Dr.
      Benicia, Ca. 94510
      866-628-8746
      TEXT ONLY: 925-989-9091 (Replied 8-4)
      www.mcbparts.com
      Email: [email protected]
      Like us on Facebook for exclusive offers, info and chat: www.facebook.com/mcbparts
      Hours: Monday to Friday 8am - 4pm Pacific
      We ALWAYS enjoy talking to our customers!
      We have a full time staff to answer ALL Questions, Tech Support or Order Status Tracking!
    2. #62
      Feb 2017
      Jeddah, KSA
      Quote Originally Posted by MCB Matt View Post
      Thanks,
      Matt
      Thank you. Just replied to your PM with some more goodies :D
      1968 Camaro SS | LSx 364ci
      T-56 | RT StreetGrip | RT Steering Kit | TRSD Disc Brakes | Wilwood Dual Piston
    3. #63
      Benicia, Ca.
      Got it and thanks again for the orders!
      Matt
      Benicia, Ca. 94510
      866-628-8746
      www.mcbparts.com
    4. #64
      Feb 2017
      Jeddah, KSA
      Ok got the tall b joints in. Also, I added the leaf top clamping plate. Visually, it does look like it was lowered a little. Ordering the Ride Tech 1" Lowering block but,
      think 1" is good enough? I prefer sticking with Ride Tech blocks, but i think they just have the 1"
      The front is way too low compared to rear.
    5. #65
      Feb 2013
      If you look back at that green car I posted on the last page, it has that 1" block installed as well. From the looks of it, your car will sit very similar to it. The wheel and tire size is the only thing that looks to be a little different but it looks like they won't be too far off from each other stance wise!
      Ridetech Suspsension
      Tech Specialist
      Phone: 812.481.4734
      Project Fox
      1979 Trans Am
    6. #66
      You'd be surprised how much a difference 1" of drop makes.
    7. #67
      Feb 2017
      Jeddah, KSA
      So decided to go with the 1” blocks + 3/8” coil spacers
    8. #68
      Before you spend the money and effort, you throw some weight in the back until it comes down an inch, and then jack the front up 3/8" to see how it will look first.
    9. #69
      Feb 2017
      Jeddah, KSA
      I would still have to raise up the front since the tires are rubbing a lot now. Needs about 3/4" raise which the 3/8" should do.. hopefully.
    10. #70
      Feb 2013
      What do you have the alignment set at?
      Tech Specialist
      Phone: 812.481.4734
      Project Fox
      1979 Trans Am
    11. #71
      Feb 2017
      Jeddah, KSA
      Quote Originally Posted by Josh@ridetech View Post
      I haven’t aligned it yet, since im adding the spacers and lowring blocks. I’m planning to align it as below
      Camber -0.75 degrees
      Caster 3-4 degrees
      Toe in 1/8”
      Is That ok with the streetgrip kit?
    12. #72
      Feb 2013
      Caster 3-4 degrees
      Toe in 1/8”
      That's pretty close to what we recommend. We typically look for somewhere between these numbers for street builds:
      Camber: -.5° to -1°
      Caster: 3° to 5°
      Toe: 1/16" to 1/8 toe in
      If you haven't aligned it yet, that could be part of the tire rubbing issue as well.
      Tech Specialist
      Phone: 812.481.4734
      Project Fox
      1979 Trans Am
    13. #73
      Feb 2017
      Jeddah, KSA
      Camber: -.5° to -1°
      Caster: 3° to 5°
      Thanks Josh, just for more info, in case the tune up shops here don't go by degrees. what would the Camber and Caster be in inches?
      also, you recommend to stay on the low or extreme side from the given degrees?(e.g. camber -0.5 or -1)
      Thank you
    14. #74
      You can’t measure caster and camber in inches. It’s degrees....
    15. #75
      Feb 2017
      Jeddah, KSA
      I see , thanks for clarifying.
    16. #76
      Feb 2017
      Jeddah, KSA
      For reference, here’s ridetech car height with lowering kit vs mine without. Over 2” lower upfront. Not sure why... could be my ac kit but.. really 2” more
      Now i have a 3/8” spacer and a 1” lowering block rear on the way... hope i got the right sizes
    17. #77
      Feb 2013
      I can't say I've had anyone have to use a spacer under the front coil springs. You said you have an LS2 in the car? Still using the factory 1st gen spindles?
      Tech Specialist
      Phone: 812.481.4734
      Project Fox
      1979 Trans Am
    18. #78
      Feb 2017
      Jeddah, KSA
      1968 Camaro: Help with Suspension Setup
      Correct, LS2. I do have AC installed, but doubt it’s causing the added drop. Factory spindles, control arms
    19. #79
      Feb 2013
      Thanks!
      What body bushings are you using? What shape are they in if they haven't been replaced?
      Also, can you post a picture of your control arm/spindle setup for me?
      Tech Specialist
      Phone: 812.481.4734
      Project Fox
      1979 Trans Am
    20. #80
      Feb 2017
      Jeddah, KSA
      Thanks!
      Sorry, not sure which body bushings. But other bushings like control arms etc all ridetech
      Below are photos taken before the install
