      Aug 2015
      suspension work on a four post lift
      HI everyone, anybody ever do suspension work on a four post lift? i have streetgrip system I want to install, and I would like to use my lift rather crawling around on the floor, but it seems difficult. Jacking up the rear frame with jack stands using the plate will be difficult, as the width of the ramps is not conducive, and I will need the jack tray to support rear. also lowering and compressing the front coils with a floor jack on the ramps is a bit sketchy as well....Looking for comments and solutions of those who may attempted to do this... It may be simpler using the floor...
      Jun 2013
      West Blocton, Al
      I use the 2 safety stands from harbor freight when I do suspension work on my cars on the four post lift. works for me
      Aug 2012
      Peoria, AZ
      I have two of these chassis Jack's and they work great for suspension work on my 4 post lift.
      Lance
      Feb 2011
      Where did you get yours? Usually they cost a small fortune.
      70 GTO - Alum 5.3/4L80e, 7875
      17 GT350
      Aug 2012
      Peoria, AZ
      Quote Originally Posted by Interceptor5588 View Post
      I bought them from Advantage with my lift. And correct, they are not cheap. I opted for the manual pump version vs air over hydraulic which saved some money though and has not been an issue. the Advantage ones are nice because they have wheels that roll on the channel inside the ramps, I found this makes them much easier to move around than the ones that just slide on Delrin blocks.
      Lance
