Page 2 of 2 FirstFirst 1 2
Results 21 to 24 of 24
  1. #21
    Beach Park IL
    I have the holley pan in my stock subframed 2nd gen with their mounts.
    The boss for the drain plug is ground flat from dragging the pavement on occasion, it just barely hangs below the crossmember.
    Have you talked to Morrison to see what pan they reccomend?
    Donny
  2. #22
    I used the CTS-V pan with my Art Morrison subframe. I vaguely recall massaging things a little but some of that was due to the alternator on the stock accessory drive. Pretty sure the pan hit the rack lines that cross over.
    1957 Buick Caballero - huge project
    1969 Mustang Sportsroof
  3. #23
    Jun 2017
    Idaho
    Ok I got the CTS-V pan installed and it fits in there with plenty of room all around and only hangs 1/2-3/4" below the crossmember. I can live with that plus it eliminated the DOD pressure bypass valve in the pan allowing for more oil pressure and provisions for mounting the LSA/LS3 oil cooler. I will most likely be building a windage tray that will protect everything under there anyway and provide less wind drag. Tried to take pictures and failed...poor lighting. I will try again next time I'm home.
  4. #24
    Quote Originally Posted by Snowcatter View Post
    That pan is even more expensive than the Holley...what makes it worth a $100 more?
    A little late, but the Mast includes a baffle kit. Holley you have to buy it separately (and they're pretty expensive - $200+).
