Results 1 to 16 of 16
    Central CA USA
    List of online calculators
    Please post any links to online calculators in this forum thread.
    You can post suspension or Engine calculators here, but please give a short explanation of what your calculator does.
    David
    Here is a page on how to calculate your suspension frequencies http://www.racingaspirations.com/app...ncy-calculator
    Colorado Springs
    Here is an engine calculators I use for displacement, compression, boost, and altitude. It is primarily focused on motercyles, but the four cycle engine data is the same regardless of # of cylinders.
    http://www.rbracing-rsr.com/comprAdvHD.htm
    TC
    Detroit Subs
    This link seems to cover quite a bit also : http://www.tciauto.com/tc/support/
    enjoy
    "BillShope" may be too modest to post his own page. There is a lot of good stuff here.
    http://home.earthlink.net/~whshope/
    Clovis, Ca
    Cologne, Germany
    These are somewhat specific in topic, but very useful if you know how to use.
    http://www.engineersedge.com/Calulators_Online.shtml
    1969 Z/28 Dropped 2" GW uppers, lowers, leafs w/delrin, QA1 coilovers w/450 lb/in, Unisteer R&P, 1" solid anti-roll bar, subframe connectors, Billet specialties SLX-45 18X8 and 18X9 with Toyo RA-1 245/40/18 and F1-GS-D3 275/40/18. C5 Z06 brakes, 408 ci LS2, Viper T56 trans.
    2007 Wildkart shifter kart with Honda CR125 engine.
    2004 Dodge SRT4 daily driver and track day car, stage 2, rear ARB, dropped 2 inches
    1997 K1500 Z71 tow vehicle
    Dec 2007
    Tire Size Calculator
    Compare tires and see actual height and speedometer difference.
    http://www.miata.net/garage/tirecalc.html
    I like this one for tire size visualization:
    http://www.rims-n-tires.com/rt_specs.jsp
    RC Engineering's fuel injector size calculator:
    http://www.rceng.com/technical.aspx?..._Injector_Size_
    (i've found it to err to the large side, you can pick the next size down and probably be ok)
    Oct 2007
    Newark DE
    Rear steer calculator. Not sure if it is accurate or not.
    http://www.chassishelp.com/rearsteer.html
    May 2007
    Quote Originally Posted by off camber View Post
    If the picture's correct, I don't see how it could be. He appears to be showing Heims at both ends, but no upper link. Rear steer is determined by more than just the angle of the lower link.
    http://www.racetec.cc/shope
    Aug 2006
    San Francisco, CA
    Derivation of Wheel Caster Geometry
    This is a reprinted SAE paper on the geometry of wheel caster, including the derivation of the equations related to measuring it on your vehicle.
    Warning, gratuitous use of trig.
    http://www.hunter.com/pub/undercar/2573T/index.htm
    Steven
    1968 Camaro: Project "TRACKDAY"
    Latest Track Weekend Video
    Build in Progress
    Aug 2009
    May 2002
    Northern California
    Country Flag: Bosnia Herzegovina
    here's a few good reference pages to be helpfull to most.
    http://torchmate.com/resource_center/reference_tables/
    MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
    https://www.pro-touring.com/image.php?type=sigpic&userid=4&dateline=1323422564
    Follow us on Facebook
    Maine
    Here is a site with a materials weight calculator with what appears to be a pretty comprehensive materials index. Tell it what type of metal alloy and of what dimensions (for all sorts of materials - round tube, solid round, square, flat sheet, etc., etc.) and it spits out the total weight. Pretty handy.
    http://www.onlinemetals.com/calculator.cfm
    John
    Central CA USA
    Here is a free online suspension geometry calculator, it's set up for 67-69 Camaro front suspension stock:
    67-69 Factory Suspension
