    Results 1 to 19 of 19
      Central CA USA
      List of online calculators
      Please post any links to online calculators in this forum thread.
      You can post suspension or Engine calculators here, but please give a short explanation of what your calculator does.
      David
      Here is a page on how to calculate your suspension frequencies http://www.racingaspirations.com/app...ncy-calculator
      Colorado Springs
      Here is an engine calculators I use for displacement, compression, boost, and altitude. It is primarily focused on motercyles, but the four cycle engine data is the same regardless of # of cylinders.
      http://www.rbracing-rsr.com/comprAdvHD.htm
      TC
      Detroit Subs
      This link seems to cover quite a bit also : http://www.tciauto.com/tc/support/
      enjoy
      "BillShope" may be too modest to post his own page. There is a lot of good stuff here.
      http://home.earthlink.net/~whshope/
      Clovis, Ca
      Cologne, Germany
      These are somewhat specific in topic, but very useful if you know how to use.
      http://www.engineersedge.com/Calulators_Online.shtml
      1969 Z/28 Dropped 2" GW uppers, lowers, leafs w/delrin, QA1 coilovers w/450 lb/in, Unisteer R&P, 1" solid anti-roll bar, subframe connectors, Billet specialties SLX-45 18X8 and 18X9 with Toyo RA-1 245/40/18 and F1-GS-D3 275/40/18. C5 Z06 brakes, 408 ci LS2, Viper T56 trans.
      2007 Wildkart shifter kart with Honda CR125 engine.
      2004 Dodge SRT4 daily driver and track day car, stage 2, rear ARB, dropped 2 inches
      1997 K1500 Z71 tow vehicle
      Dec 2007
      Tire Size Calculator
      Compare tires and see actual height and speedometer difference.
      http://www.miata.net/garage/tirecalc.html
      I like this one for tire size visualization:
      http://www.rims-n-tires.com/rt_specs.jsp
      RC Engineering's fuel injector size calculator:
      http://www.rceng.com/technical.aspx?..._Injector_Size_
      (i've found it to err to the large side, you can pick the next size down and probably be ok)
      Oct 2007
      Newark DE
      Rear steer calculator. Not sure if it is accurate or not.
      http://www.chassishelp.com/rearsteer.html
      May 2007
      Quote Originally Posted by off camber View Post
      If the picture's correct, I don't see how it could be. He appears to be showing Heims at both ends, but no upper link. Rear steer is determined by more than just the angle of the lower link.
      http://www.racetec.cc/shope
      Aug 2006
      San Francisco, CA
      Derivation of Wheel Caster Geometry
      This is a reprinted SAE paper on the geometry of wheel caster, including the derivation of the equations related to measuring it on your vehicle.
      Warning, gratuitous use of trig.
      http://www.hunter.com/pub/undercar/2573T/index.htm
      Steven
      1968 Camaro: Project "TRACKDAY"
      Latest Track Weekend Video
      Build in Progress
      Aug 2009
      May 2002
      Northern California
      here's a few good reference pages to be helpfull to most.
      http://torchmate.com/resource_center/reference_tables/
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Maine
      Here is a site with a materials weight calculator with what appears to be a pretty comprehensive materials index. Tell it what type of metal alloy and of what dimensions (for all sorts of materials - round tube, solid round, square, flat sheet, etc., etc.) and it spits out the total weight. Pretty handy.
      http://www.onlinemetals.com/calculator.cfm
      John
      Central CA USA
      Here is a free online suspension geometry calculator, it's set up for 67-69 Camaro front suspension stock:
      67-69 Factory Suspension
      Pacific Wonderland
      Transmission and gear ratio calculations with MPH at RPM.
      https://weddleindustries.com/gear-calculator
      If it breaks I didn't want it in the first place.
      69 GTO
      72 FIREBIRD
      64 BONNEVILLE FUNERAL COACH
      70 JAVELIN
      52 F1 FORD PU
      29 FORD PU
      85 ALFA ROMEO
      ASSORTED DUCATI'S
      91 BLAZER LOWRIDER
      Nov 2010
      Jonesboro, Arkansas
      Here's a couple of apps that are pretty informative..
      https://www.tremec.com/menu/tremec-toolbox-app/
      This is a spicer calculator that's interesting:
      https://spicerparts.com/calculators/...rpm-calculator
      Carl Wilson
