    Sep 2019
    Default Trans Am 1980 turbo swap engine
    ​Hello all ..
    I just joined with you.
    i have Trans Am 1980 turbo
    and i want to swap engine to L99 6.2L with gear 6L80E.
    I have bought a whole car which runs perfectly,( Camaro SS V8 6.2 engine modal 2011 automatic )
    So i will swap everything from the camaro SS to the old car Trans Am 1980 turbo.
    Please advise me What is the best complete Conversion Kit?
    Thank you
    Default
    I'd go over to LS1Tech.com. They have all the info you are going to need.
    Pensacola, FL
    Default
    Look into all of the Holley swap components- engine mounts, crossmember, oil pan, headers, etc. Some well thought out components that were engineered to work together and fit well. You'll probably have to change the front acc drive. The trans tunnel in 70-81 body is pretty tight. I am unsure if that trans would fit without mods. I'm sure that swap has been done before, and Holley I'm sure can inform you on it. Sounds like a great project. Always liked that turbo T/A body.
    Apr 2004
    OKC, OK
    Default
    tunnel will need cut
    Mike Redpath
    Musclerodz & Customz
    405-288-0189
    pro-touring parts specialists
    Musclerodz.com
    facebook page
    instagram
    Musclerodz
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
