      Sep 2016
      Bakersfield, CA
      Any do exhaust wrap + cermaic coating?
      I live in the CA desert and underhood heat can be INTENSE, especially in traffic on 120F+ days.
      I had the idea to get my headers ceramic coated inside and out PLUS wrap them. But I have people on certain online forums saying that even with inconel exhaust valves, I'll still burn up my valve and guide.
      Is there any truth to this? If so and I can only do one or the other, which of the 2 will reduce heat the most?
      Thanks!
      http://www.TheFOAT.com/92GTA
      1969 Pontiac Firebird
      w/535ci IAII aluminum block, Dailey dry sump, Holley EFI (full road race build). Primer black w/black interior.
      Sep 2016
      Bakersfield, CA
      I've recently stumbled upon this coating while reading a magazine. Thoughts on this compared to wrap?
      http://swaintech.com/race-coatings/r...aust-coatings/
      Jan 2014
      Portsmouth NH
      I had a pipe done for one of my motorcycles 18 years ago by Swain. It is on my Ducati M900ie and has about 38k miles of run time on it, many at the race track so it has been definitely field tested. It has held up very well, some discolouring but mostly from use and road grime. The coating is completely still bonded and in great shape. Good company and have great products. I would recommend it and Swain.
      Steve
      Sep 2016
      Bakersfield, CA
      Awesome, that's great to hear. Thanks!
      Sep 2015
      Contact Capps powder coating in Fresno. The do great work.
      Mar 2013
      Sunny Calif
      I used the DEI wrapping to cover just the top and side portion of the headsets so moisture can escape and mitigate any premature rotting.
      Sep 2016
      Bakersfield, CA
      I finally settled on going this route: https://headershield.com
