      SoCal
      what kind of gear oil to use
      I'm running a 9" Strange locker. Would you recommend regular valvoline, or mobil 1 synthetic?
      Feb 2004
      McKinney, Texas
      What oil
      If it's a new center section, break it in with regular gear oil then go with a synthetic. IMHO the best oil you can buy is AMS oil. That's what I will be using once mine is broken in.
      Kirt
      1969 Camaro 427ci LS1 Twin Turbo
      Wade's Rod & Custom
      SoCal
      Is there a break-in period for a rear end like there is for an engine? Change after the first 1,000 miles? Also, how much fluid goes in a rear end?
      TTT: Anybody got an answer to Tom's question: how much fluid does a Ford 9" take?
      jp
      John Parsons
      Central Florida
      SoCal
      Woah, this is old... I already filled it with regular Valvoline which is what Strange recommended. Its been so long I don't even remember how much I used... Just filled until it started to come out the axle tubes from what I recall.
      Jan 2003
      Arizona
      Buy four quarts. Fill your rear til it starts to weep out of the fill hole. Will probably hold 3 and change (plus mess makes four )
      ________________
      Steve Chryssos
      Cool ... thanks Steve. I got 2 quarts and only put one in. It's no big deal when your ride only makes power when the engine is cranking.
      I've heard one can make big power by getting the engine to burn gasoline.
      jp
      John Parsons
