    Results 1 to 20 of 29
      May 2019
      18"/19" stagger pic's
      Looking for some 70 Chevelle pic's with 18"front and 19" rear wheels. Probably go with 315/35 rear and 275/40 front but want to get some ideas on looks before I drop the $4k
      Oct 2015
      19” front and rear
Size:  417.0 KBName:  370E0730-ABD7-4C9A-B449-89D6426966A8.jpg
Size:  437.6 KBHere are some pics of my GTO with 19” wheels front and rear. 345/305 tires.
      Quote Originally Posted by ram540 View Post
      Is there a particular reason you want to run 19s in the rear and 18s in the front?
      May 2019
      Not really just seeing alot of 18/20" combinations lately and i think 20's in the rear just don't look right.
      May 2019
      Quote Originally Posted by 968ls1 View Post
      What width and back space are you running? And any modification to the rear to get 345's to fit?
      I agree, but I also don't see a need to stagger wheels at all. Look at Tom's GTO...it looks amazing with 19s all around. A light stagger is achieved with having the front tire be slightly smaller in diameter than the rear tires.
      - - - Updated - - -
      It's tubbed.
      Oct 2015
      12” with 7-1/4” back spacing. Rear is mini tubbed, front fender are slightly modded as well. If I had to do it again I would just run 315/30/18 front and rear like the UMI LeMans and save a lot of time and $$. Andrew is correct my rear tires are 27.2” diameter and the fronts are 26” so it gives me a slight rake. I don’t like the look with staggered rim diameters.
      Oct 2015
Size:  126.6 KBName:  7A027543-89B1-4C0D-90D1-57A3FAA40425.jpg
      Rear shots sorry for poor quality.
      Anniston, Al
      The rear wheel opening is so big you almost need a 20. I think a 20/19 would look good.
      1967 Firebird (current project)
      1967 Firebird (unfinished project SOLD)
      With 20" the sidewall starts looking small and the weight of the wheels and tires starts to become an issue. Unsprung weight not only effects handling, but also ride quality.
      Anniston, Al
      I definitely wouldn't want a smaller sidewall, I'd run a tire with roughly a 4in tall sidewall on a 20 and that should fill out the opening. And I'm mainly talking about the fore and aft gaps that need to be filled up. I think the car below looks good, it's a 19/20 setup.
      Putting a tire with 4" of sidewall on a 20" wheel is going to give you a tire that is way too tall. I find that a 27" tire in the rear looks optimal. The front can be just a little shorter to give a balanced look.
      You really have to look at the available tires in the proper sizes and tread ware.
      For a car that doesn't have frame or body modifications, a great looking combination is 295/40-18 in the rear and 255/40-18 in the front. The rear is a hair over 27" and the front is right at 26" tall. Falken 615s are available in that size and are excellent tires.
      This looks pretty awesome:
      https://www.pro-touring.com/threads/...%96-5-00%94-bs
      The Nitto NT05 tire is available in a 295/40-18 and 275/40-18. That would look fantastic and it is a great tire.
      https://www.nittotire.com/passenger-...formance-tire/
      Oct 2015
      When I smoke the Innvos on the car now, I am going to the NT05 for some more grip.
      May 2019
      That's exactly what I was thinking about going with. Right now I have 245/40-18 in the front and 275/40-18 rear but they are on 8" and 9" wheels. Was only thinking about going with the 18"/19" combo because I'm going to get some different wheels and want to go as wide as possible in the rear. But I'm thinking i'll stay with the 18's. Here's what she looks like now.
      Mission Viejo, CA
      19"/19" 275/35 and 305/35. Front is 26.7", rear 27.4". Name:  20181009_123524.jpeg
Size:  84.8 KBName:  20181009_123458.jpeg
Size:  163.9 KBName:  20190810_123016.jpeg
      1973 Hurst Edition Pontiac Grand Am: 430 CI of ERL built LS7, Tremec Magnum T-56 6-speed, Global West / Speedtech Suspension, Custom rear coil-over suspension, QA1 double adjustable shocks, Wilwood 6/4 piston disc brakes, Modulare C1 19" concave wheels. Shooting for 625 HP and 20 MPG!
      Quote Originally Posted by Later-A-body View Post
      19"/19" 275/35 and 305/35. Front is 26.7", rear 27.4". Name:  20190810_123016.jpeg
      Is this a photoshop? It looks like the bottom of the tire is gone? Car looks great btw.
      Anniston, Al
      Looks like he's just parked next to a sidewalk.
      Quote Originally Posted by Wall View Post
      Oh geez, that's it. Hard to tell there's sidewalk from that angle in the picture, so it just looks weird. Thanks for pointing that out.
