    Page 6 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
    Results 101 to 120 of 130
    1. #101
      You do some awesome work! I love checking in to see your next post.
    2. #102
      NJ
      Thanks Wayne, but wish I could say it was MY work. There's a fabricator local to me that I've become friends with over the years and this is all his work. He's a 2 man operation, has his hands in every part of the build and nothing goes out the door without his approval.
      I just steal all the ideas from forum members builds such as your own, mix it with my own ideas and he makes it work!
    3. #103
      Sep 2009
      Looking great! Love seeing the progress pictures.
    4. #104
      Jan 2009
      NYC
      care to sell the red wheels ?
      yes it does have positraction
    5. #105
      NJ
      Quote Originally Posted by ponchoblue View Post
      Sorry, they've been sold already.
    6. #106
      Wisconsin
      The 67 is Looking good John! Glad you are able to get back on the car...... mine is so close, like you, I got side tracked with life, etc..... I bought the rear spring pocket kit after I had repainted the bottom and got everything assembled. :( Just talking myself into getting it installed now!!
      Used to be known as classiccamaro
    7. #107
      NJ
      DSE clutch master cylinder mount installed. Welded around the perimeter and made some filler pieces to close out the bottom portion that angles out from the firewall to completely seal off the engine compartment from the interior.
    8. #108
      NJ
      Quote Originally Posted by DKz Garage View Post
      Thanks Dave! I can imagine the anxiety grinding and welding on fresh paint! You won't be sorry though! I look forward to more updates on your car!
    9. #109
      Sep 2017
      Quote Originally Posted by John McIntire View Post
      John,
      Wish I would have thought about doing that before paint. That's a great idea to strengthen it and seal it separately.
      Keep up the progress
      tankmasterj
      Jason
      TANKMASTERJ
      Jasons Toys
      2000 HD Softail
    10. #110
      NJ
      Let's talk about cross members.
      I dropped my mock up engine in the DSE subframe using their 1.5" setback mounts. I used the Bowler Transmission transmission cross member and it fit. It has slots that allow you some room for adjustment. While it does fit, I really wanted to use the Holley one, as it allows for more exhaust clearance while running through that area, and I have the exhaust from Holley made to fit and work with complete DSE set up.
      Well, that doesn't fit. It's only made to work with the stock subframe and their LS engine mount kit. I do see that they make one to fit an LT engine with the DSE subframe, but I didn't want to try it and just wind up wasting my money. The Holley one is fixed in position, no wiggle room, just a little in the transmission mount area with some slotted holes.
      So instead, we elected to go the route DSE does and a few other shops do and make a small cross member that just spans the tunnel mounted to the floor pan with doubler plates on each side for added strength. Here are a few pics:
      Here you can see the top plate formed to the floor pan. The bolts are just there to keep it in position and help suck it down to the floor pan.
      Everything welded up, the bolts will be removed and the holes welded up.
      Here's what the bottom looks like with the additional plate all welded up.
      Now just need some mounting tabs and the actual cross member to be fabricated, an I'll have a nice compact setup that'll allow for plenty of exhaust clearance.
    11. #111
      Nice progress!
      Instagram @projectgattago
      Dr. EFI
    12. #112
      Sep 2017
      I sure like the fabbed up bandaids for a bolt in crossmember, that's a great idea. Speedtech ndoes a similar deal with there rear suspension cradle. It has a couple plates that weld the rear crossmember and bolt through trunk floor.
      Nice progress and update
      TANKMASTERJ
      Jasons Toys
      2000 HD Softail
    13. #113
      Jul 2019
      Ohio
      Good idea. Do you have a target for where you will end up with your drive train angle relative to the subframe with the crossmember?
    14. #114
      NJ
      Quote Originally Posted by srode View Post
      Yes, the goal is 2.5-3 degrees down. Should be very possible with the modified trans tunnel.
    15. #115
      Apr 2018
      Tennessee
      Nice ride. Great craftsmanship and continue the good work.
    16. #116
      NJ
      Quote Originally Posted by Huff_diesel View Post
      Thank you!
    17. #117
      NJ
      Test fit the headers. These are the Hooker Blackheart ones from Holley.
    18. #118
      NJ
      The fit and finish looks great on these headers. These are they larger ones they offer with 2" primaries. There is just one slight minor interference on the driver side engine mount that is probably nothing. One of the primaries is resting on it just touching it. I'm thinking it's nothing because the mock up block has no head gaskets and I didn't install header gaskets for the mock up. Those things might be enough for the correct clearance. If not, a quick hit with the grinder and all is good.
      I have a set of the DSE headers, but am wanting to run these Hooker ones so they'll mate right up to the exhaust that they make. If I use the DSE headers, I'd have to make a small piece to connect the headers to the midpipe, or just have a complete exhaust fabricated from the collector back. The DSE ones do have a nice V-band clamp at the collector.
    19. #119
      Nov 2018
      That's tight on the driver side. Have you installed the steering shaft to see if it's going to clear? It'll be tons easier now than when the fenders are on.
      2021 Durango R/T
      2005 Dakota beater
      2003 Dakota project-o-mobile
    20. #120
      NJ
      Quote Originally Posted by Vimes View Post
      Yes, that will definitely be done at this stage. I have a new Ididit tilt column to replace the stock one you see in the photo. When that's installed we'll install the swivels and cut the intermediate shaft to length in order to connect the column with the rack.
