    Page 5 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
    Results 81 to 100 of 130
    1. #81
      Feb 2013
      Good work man!
      Ridetech Suspsension
      Tech Specialist
      Phone: 812.481.4734
      Project Fox
      1979 Trans Am
    2. #82
      Jul 2018
      Quote Originally Posted by Just 1 More View Post
      Where did you get those subframe attachment brackets?
      Quote Originally Posted by John McIntire View Post
      They're included in the subrame connector kit from DSE.
      I made the call to DSE and they are available separately so I placed my order
    3. #83
      NJ
      DSE Heavy Duty leaf spring pockets
      Here's a few pics of the Detroit Speed heavy duty leaf spring pockets being installed.
    4. #84
      NJ
      All plug welded up and ground smooth. There will be some stitch welds around the perimeter to finish it off.
    5. #85
      Jul 2018
      I just did my HD pockets, haven't welded them in yet. I was thinking of not welding and just letting the bolts do their job. Any reason you can think of that not welding them in would be a problem?
    6. #86
      NJ
      I would definitely weld the plate to the floor, even if you just plug weld all the holes. As you know the plate is significantly thicker than the floor pan, I would worry about torque transfer to the bolts and having that plate move around elongating the holes in the factory floor pan. I know there are 9 bolts holding it now, but you went through the effort of buying and installing it, it won't take more effort to finish it the right way.
    7. #87
      Jun 2015
      Country Flag: New Zealand
      nicejob ,what thickness are the plates?cheers
    8. #88
      Jul 2018
      Good points and you're 100% right.. i'll break out the welder
    9. #89
      NJ
      Here are a few pics of the trans tunnel.
    10. #90
      NJ
      I had a bolt in plate made in order to access the top of the transmission so I could easily get to the shift mechanism. It's also able to be rotated 180° in case I want to move the actual shifter location.
    11. #91
      Nice work on the tunnel!
      Instagram @projectgattago
      Dr. EFI
    12. #92
      NJ
      Thanks Andrew, the hard part is going to be where it mates to the firewall. That's in the process of being smoothed.
    13. #93
      NJ
      With the DSE setback mounts, the engine is pretty close to the firewall as you've seen in previous posts. I don't know if making the firewall completely flat will be enough. I'm thinking of a small indent/recess around the top for added clearance. I'll know more when we have a flat panel in there...
    14. #94
      NJ
      Got the 12 bolt housing in place and mocked up. Locating the upper mounts for the coil overs in the cross member now.
    15. #95
      NJ
      Here's a pic of the Heavy Duty spring pocket from DSE from beneath the car. Very solid, secure piece now! Went from 3 bolts in the factory sheet metal to 9 in a much thicker steel plate!
    16. #96
      NJ
      Here are a few pics of the panel fabricated to cover the firewall. I'm going for the complete shaved, clean look. I'll be running a RainGear wiper system so no need for the wiper motor hole, Vintage Air which cleans up the passenger side, and I'm relocating the factory fuse block bulkhead so you will not see any wiring exiting in that area.
    17. #97
      Sep 2017
      Looks killer on the. Full firewall smooth. I did partial from the steering column to the passenger side but left all the stock holes for column, clutch, wipers etc. Since I have decided on rain gear also. Wish I had thought it out better.
      I'm going to use a billet aluminum cover machined to cover the old wiper hole and attach the VIN to it.
      Keep up the nice work
      Jason's 67 pro touring camaro build thread
      Jason
      TANKMASTERJ
      Jasons Toys
      2000 HD Softail
    18. #98
      NJ
      Quote Originally Posted by TANKMASTERJ View Post
      Jason
      Thank you. I've been taking notes from everyone's builds and trying to do everything the first time around. Sounds like you have a good solution for your wiper motor hole on the firewall.
    19. #99
      NJ
      Been awhile since my last update. Just busy with life!
      Here is some more work done on the firewall. The small notches that were for the windshield wiper squirters are being filled for a nice clean look. It's a small detail, but will give me the super clean engine bay I'm going for.
      Still working on the trans tunnel where it mates to the firewall, making sure there's enough room for the DBW pedal. Also making sure there is enough room at the rear for the intake manifold and the associated plumbing and wires.
    20. #100
      NJ
      Also filling the stock location where the factory fuse block bulkhead comes through. I'm going to move it more to the side so the wires coming through the firewall in to the engine compartment can be hidden more easily!
      Next up, the MC bracket for the clutch from DSE!
