    Page 3 of 3 FirstFirst 1 2 3
    Results 41 to 46 of 46
    1. #41
      Quote Originally Posted by 70chevellemalibu View Post
      Im miss matched for now.
      new falken azenis rt615k 255/40/17 in the front.
      older Nitto nt555 285/40/17 in the rear
      i bought the rims used and they came with bald fronts and newer rears.
      I've had those tires on my GTO before (not simultaneously) and I never had much road noise from the tires.
      Instagram @projectgattago
      Dr. EFI
    2. #42
      Sep 2011
      Southern Ontario
      What happens if you shift to neutral while it’s happening?
    3. #43
      Apr 2013
      I think it goes away.
      Went 80 shift to neutral noise went away; i had to do it a few times as when I left off the gas and shift into N the car slows down also.
      If this is in fact pinion noise like you suggest can I leave it this way? Where I live our speed limits are 60 mph so it’s not like I do 80 everyday. Is there premature wear happening that could result in a part in the diff breaking and causing tire lock up at highway speeds?
      1970 Chevelle Malibu 350 "70 Hell"
      - UMI - Kore3 - LS1 4 wheel discs - Budnik
    4. #44
      This can easily be the ring and pinion making noise. R&P noise is odd, because it can manifest while under load, or off load, depending on the particular gear set.
      At this point I don't think that it is related to driveline angles, since you don't have a vibration.
      Dr. EFI
    5. #45
      Oct 2011
      You mentioned that your exhaust is touching the tranny cross member I believe. I wouldn’t discount that as being the source of your sound. It could be certain rpm produces certain vibration that translates to a harmonic noise in the car. Try to adjust so it’s not touching. Could be an easy fix. Maybe wrap the part that’s touching with exhaust insulation and the cross member as well just to create some sound barrier (just as a temporary fix).
    6. #46
      Sep 2011
      Southern Ontario
      In my opinion you can leave it alone if that’s the problem. I drove my old 70 dart like that for years.
