      Jun 2015
      Flagstaff, AZ
      No fuel pressure in rail!
      I have searched the heck out of this and haven’t found a resolution...
      Swapping an LS1 into my 72 Camaro. PSI stand alone harness and MSD inline fuel pump with C5 regulator.
      I cannot get the engine to start and there is no pressure in the rail per the Schrader valve. When I pull the hose off at the rail, plenty of fuel comes out when I turn the key and the fuel pump primes. As soon as I reattach the fuel hose into the rail, NOTHING. I pulled the rail and cleaned it out with compressed air and fuel injector cleaner getting a little gunk out. I also bought a new $130 MSD pump to ensure the original one wasn’t a lemon brand new out of the box.
      I dont know what else to trouble shoot. All that is really left is the pressure pulse dampener being clogged/ faulty or the rails just being faulty which I don’t even know if is even possible.
      Please help!
      Thanks, Jim
      Jim
      1972 Chevrolet Camaro R/S
      Sep 2014
      Sun City West, AZ
      Are you hearing the fuel pump running for a few seconds when you turn on the key? If it does run for a few seconds, check the fuel pressure regulator diaphragm.
      Kenny Mitchell
      [email protected]
      Are you sure that the ECU is getting power when the key is in Run AND crank?
      Instagram @projectgattago
      Dr. EFI
      Jonesboro, Arkansas
      Sounds crazy, but what about checking for filters being stopped up. Don't see it happening, but who knows? I believe I would work backward from the rails and eliminate the problem that way. Check pressure at the rails and go backward checking pressure.
      Carl Wilson
      Houston, TX
      ^^^ this. And make sure you don't hook up the C5 filter/regulator backwards. C5 filter has 2 outlets (return/rail). The return is in the center of the filter body, inline in with the inlet.
      Tu Ho
      Firebird V2-LS swap
      Jonesboro, Arkansas
      Did this ever get resolved? Just curious what the problem was
      Carl Wilson
