      Jun 2010
      Deployed
      Can Earl Fittings be used on Russell Hose
      I'm in a pickle...Im installing a oil cooler adapter using Russell hose and fittings. Turns out I need a 60 degree fitting and Russell doesn't have one!!! WTH
      I want to have hope that Russell's "Pro Classic Hose" is the same as Earls "Pro-Lite"...Being AN spec nylon braided hose...Can a Earl fitting be used on Russell hose?
      I would hate to have one use one brand the other something else.
      I have -10 fittings is someone can give me some specs for Earls for comparison.
      1970 Camaro/DSE build
      Oct 2014
      DFW, Texas
      I've had no problems mixing hose and fitting manufacturers, as long as the sizes [#AN] and type [rubber, PTFE] then it's probably just fine.
      Nevertheless, I always air pressure test my AN lines before installing.
      1972 Plymouth 'Cuda - Not LS-swapped, 5.7L Hemi [MS3 Gold Box], T56 Magnum 6-speed - 'Cuda Build Page
      1976 Dodge D100 - Warlock
      2016 Subaru WRX - E30 Tune
      Feb 2019
      Kankakee IL
      I have both Russell and Earls fittings being used with Russell hoses on my car. Both make a quality product and as both fittings are intended for that type hose I don't believe you'll have any issues.
      Tracey
      Jun 2010
      Deployed
      Well still on the hunt. Got the Earl fitting and learned there is another type known as “cutter”. Wish summit racing's site would have mentioned that. Looks like Jegs does. Trying Raceflux...
      Feb 2019
      Kankakee IL
      I go directly to the manufacturers website for fitting info. Summit and Jegs just cut and past on their sites and sometimes leave something to be desired.
      Tracey
      Jun 2010
      Deployed
      Raceflux fittings work with Russell hose. Got the fitting yesterday, despite the design being slightly different, the specs are the same.
      On another note...these fittings get hard to assemble towards the end. -6 and such not too bad, but these bigger hoses worry me I’m going to snap the nipple off. Are these that tough? I’m now starting to contemplate using crimp fittings.
      Vacaville CA
      For what it’s worth, the fittings in your picture are for two different types of hoses
      Mar 2013
      Sunny Calif
      93GT is correct and yes Yoo can successfully mix and match different manufacture AN components as long as same design.
