      New Coilover Kits for GM A-Bodies from Hotchkis
      Imagine controlling the grip, ride and handling performance of your
      muscle car from your smart phone! Our revolutionary new Coilover Systems are adjustable manually or electronically with an advanced Bluetooth
      network to easily alter the damping forces from acceleration,
      braking and cornering parameters you specify.
      Our new ultra-premium, American made Coilovers, developed in conjunction with off-road specialist Falcon Shocks, are competition proven with the Street Machine autocross class win at Goodguys Del Mar 2019!
      The Coilovers are full of industry leading features including our premium adjustable aluminum monotube shocks with CNC machined pistons, digressive valving, precision machined oil/gas separators and filled with long-lasting Red Line Oil shock fluid. They’ve also undergone a 200 hour salt spray test for durability.
      The manually and electronically adjustable shock systems feature our wide range 8-way rebound settings. The electronic systems provide nearly infinite damping activation and includes our electronic controlled shocks, master in-car control unit, cockpit controller switch and our military-spec wiring harness.
      Complete kits are available for ’64-’67 and ’68-’72 GM A-bodies! Each package includes mounting hardware, fabricated brackets and our unique front A-Arm installation kit. Our sport coil springs are wound from high tensile strength steel for endurance and are rated at 700 lbs/inch front and 350 lbs/inch rear. You can also adjust the ride height down 2” - 4” from stock to achieve the perfect stance of your Chevelle, El Camino or GTO.
      • Complete Coilover kits featuring manual or electronic/Bluetooth adjustments
      • Lightweight monotube shock features a hard coated, CNC machined piston, precision oil/gas separator and super tough seals for leak-free service
      • Patent pending shaft damping adjustment technology
      • High tensile coil spring wire for endurance and anti-sag
      • Easy-to-use app for initial setup and shock adjustments
      • Adaptive mode provides a comfortable ride with increased shock control when required
      • GM A-body kits include laser cut mounting brackets with grade-8 hardware
      • Service, customization and electronic upgrades are available in our new dedicated Shock facility in Mooresville, North Carolina
      Second gen Camaros coming soon along with other applications!
      Jan 2017
      pickering ontario canada
      Sounds pricy
      1971 chevelle LSA 700hp -
      Quote Originally Posted by 1sikride View Post
      Sounds pricy
      Prices start at $2,195. Certainly not the least expensive option, but we feel like you get a heck of a lot for the money.
      Jun 2010
      Deployed
      I know this may be out of line, but do you have these shocks in a application to fit Detroit Speeds frame and Quadra link?
      1970 Camaro/DSE build
      Jan 2012
      Glendive Montana
      I was checking out the coilover shocks to see if they have anything for my C10 and there wasnt a direct application yet but there is a universal non electronic and electronic version of there coil overs . I'm sure they can get a set to match the system you would like.
