      Jan 2013
      ST George UT
      1970 C10 Pro Touring LS, Frame off. Might trade for 68-69 camaro
      I will try and get current pictures this weekend.
      Update.
      New front and rear glass installed. So now all new glass is 100% installed.
      I had the whole inside of the truck, including firewall dynamat 2x for heat and sound. Then had the whole inside of the firewall heat/jute padded, then black carpet for show finish.
      The vintage heat and a/c is 100% fully installed.
      Painless fuse box is custom mounted. All modules and ECM and mounted under dash. ECM is 100% wired in.
      All wiring is done (except stereo and power windows) and everything works as designed.
      1970 c10 original short bed.
      Has 72 front end.
      Frame off restoration with all period correct original sheet metal.
      Motor is a LS1 with 4l60e transmission. 35 k on motor and transmission.
      Firewall has been smoothed, Fuel tank relocated to rear frame rails and custom fuel filler in driver rear side marker light.
      Paint is hugger orange, still have 3/4 gallon left to go with truck. Truck needs interior and glass installed to be finished comes with a buddy bucket seat that needs redone parts list includes
      -Air tech air ride (installed)
      -Accuair elevel controller (installed)
      -Slosh front inner wheel tubs, painted body color (installed)
      -Slosh fender fill panels, painted body color (installed)
      -Core support fill panels, painted body color, not yet installed
      -3 core aluminum radiator with electric fans (installed)
      -Porter built hood hinges (installed) I have the updated hood hinges with added hood shocks not yet installed.
      -Boyd aluminum full tank with fuel pump built in, relocated to rear frame rails (installed)
      -All black braided fuel lines and fittings (installed)
      -New brake lines (installed)
      -CPP big brake kit, Front and Rear (installed)
      -Painless wiring harness. (Installed)
      -Headers and custom exhaust dumped and the rear axle (installed)
      -Frame has been smoothed and painted
      -3:73 gears and posi in the rear end
      -Intro or Boss 20 inch weels with brand new tires Or Intro wheel in picture. Your pick of wheels.
      -New door seals (installed)
      -New ignition key set (installed)
      -New emblems (installed)
      -New grill (installed)
      -New bumpers (installed)
      -New tail lights & head lights (installed)
      -Complete cab of truck is dynamat for sound.
      -New battery is relocated to under cab on frame rail.
      -Vintage heat and A/C all installed Including LS bracket and new a/c compressor.
      -Dakota Digital new RDX gauges. Look factory. ($1,300) Mounted, not yet hooked up.
      -New gauge bezel. (installed)
      -New black dash pad. not installed.
      -Electric Life power windows. (Installed)
      -Complete new wing window assemblies installed with new smoke glass. (insatlled)
      -New smoked side glass. (installed)
      -All new side glass seals, fleets and rubbers. (installed)
      -Ididit tilt steering column, powder coated black. Not installed.
      -New factory a/c controller converted over for the vintage a/c. (installed)
      -Lokar black engine oil dip stick. (Installed)
      -Lokar black transmission dip stick. (Installed)
      -New smoked rear glass and new seal. (Installed)
      -New new factory front windshield with new seal. (Installed)
      -New e-brake assembly. Not yet installed.
      -New head light switch. (Installed)
      -New wiper switch and knob. (Installed)
      -New windshield wiper arms and blades. Not yet installed.
      -New electric life power window switch kit. Not yet installed.
      -Dakota digital module to hook transmission gear selector to gauges. Not yet installed.
      -Dakota digital OB2 module for easy gauge wiring to factory LS computer. Not yet installed.
      -Retro Sound blue took radio for factory dash. Not yet installed.
      -New carpet seal plates. Not installed.
      -Lokar black billet gas pedal assembly. Not yet installed.
      -New driver and passenger outside mirrors. Installed.
      -New stainless button head complete truck bolt kit. Not yet installed.
      -New rearview mirror and new bracket. Not installed.
      -New interior dome light assembly. Not yet installed.
      -New glove box light assembly. Not yet installed.
      Everything you will need to finish the truck is new and included. except interior. I was going a have custom interior.
      To many parts to list
      Truck was taken down to metal and frame off. Cab is painted upside down right side up. Truck does run and drive like I said just needs interior to be finished.
      A/c and heat is complete and installed with all factory ac cab vents.
      $43,500
      Location San Jose CA
      Will trade for a 1968-1969 Camaro
      Jun 2019
      San Jose CA
      Very nice C10. GLWTS
      Jan 2013
      ST George UT
      Thank you.
      Just ordered all the parts to finish the truck. Its getting a/c, p.w. glass and gauges this week.
      Power windows, new wing window assmeblies & new side glass is installed.
      Under the dash Vintage a/c installed.
      New factory a/c controller converted to Vintage a/c installed.
      New RDX gauges installed in new bezel and mocked up.
      Jan 2013
      ST George UT
      Here are a couple current pictures.
      Nov 2011
      Livermore, CA
      W0w sexy for sure..
      Livermore, CA
      American:
      1966 Chevelle SS "Tribute" Retro / Pro-Tour
      For Sale
      Oct 2013
      Still available?
      Jan 2013
      ST George UT
      Sorry
      Sold
