06-20-2019 #1
Coil over trouble JRS suspension.
Front suspend = JRS apex C6 based suspension.
Qa1 Coliovers:
When i take the weight off the wheel and allow the suspension to hang he upper arm hits the spring unless I screw the lower spring adjuster on the coil-over almost all the way up which make the ride height too high.
if I try to lower the spring adjuster down, to get the right hight down.. the spring will unseat less then half of the way down the adjustment, it will sit once i put weight on it but that seems wrong..
I wouldn't be shocked to hear I need different springs.. smaller diameter or fee length.
Thoughts appreciated..From a place you will not see comes a sound you will not hear....
67 Camaro In progress
06-20-2019 #2
