    Results 1 to 12 of 12
    Thread: Sensor location
      Mar 2013
      Country Flag: Belgium
      Sensor location
      Simple question, simple solution most likely....
      In the right is my sensor for the electric fan, to the left is going to be the connection for the heater.
      So where can i install my temperature sensor for the temp gauge inside the car?
      I was thinking to put it on the thermostat, remove the bolt holding it and screw it in there,
      Is that a possibility?
      First build guys, most of this is new to me...
      Apr 2010
      Jersey Shore
      your temp gauge sensor is going to be NPT thread, where your thermostat housing bolts are likely just NC... if there are no other port locations on the engine, you could get a T fitting (which wouldnt look so great IMO) or drill and tap the manifold for another port near the thermostat
      -Chris
      '69 Corvette
      '55 Chevy Hardtop
      AutoWorks Middletown, NJ
      Feb 2019
      Kankakee IL
      There’s no port at the fan for the fan sensor?
      Or, is there a way to split the signal from one sensor to two units?
      Tracey
      Mar 2013
      Quote Originally Posted by vette427-sbc View Post
      I agree on the T fitting not looking nice....but so far it looks like the only option, not that keen on drilling a hole in the intake..
      See no other connections besides a few higher on the intake, close to the carburator, but those are only letting air flow through, correct?
      - - - Updated - - -
      Quote Originally Posted by Tsaints1115 View Post
      And was thinking about this too, but i think this means getting a T fitting as Vette said...
      Mar 2013
      As said, one port left next to the car , but this is not letting water trough or is it??
      Feb 2019
      Kankakee IL
      That's a vacuum port for the #4 cylinder.
      What I meant on one sensor/2 units was to run the wiring for the fan and gauge to one sensor. It's a temp sensor, it provides a reading that the fan/gauge act off of. Why would the sensor care how many things are receiving that signal?
      Tracey
      Mar 2013
      Good one, makes sense what you are saying but i think, and it just a tought,
      the sensor for the fan is for 200fahrenheit, so i will probably only send a signal once its reaches that temperature on which the fan will activate.
      Will give it a try though!
      Feb 2019
      Kankakee IL
      Does it "send a signal" or a constant reading that the fan activates once it reaches temp?
      Much like a fuel level sender sends a constant signal to be read by that gauge?
      I could be completely wrong but it's worth a shot.
      Tracey
      Mar 2013
      got fuel pump issues now, so before i can test this i need to sort the fuel pump our and might have to buy a new one so this will take a few weeks...
      Will get back to you on this one!
      Feb 2013
      Is something like this available for the engine you're using?
      https://www.cjponyparts.com/thermost...5-1973/p/TH16/
      Mar 2013
      should be....will look around,
      engine is a 408 based on the 351w.
      Just need a thermostat that is angled 90degrees up for the radiator hose. ( no space for a straight connection).
      Thanks for the tip!
      Mar 2014
      Yuma, AZ
      Give this a try, it has a spot on top you can drill and tap to put a sensor. I have the same housing on my car, since it's a real Ford part it's good unlike most aftermarket housings.
      https://www.summitracing.com/parts/f...-m90/overview/
      Nelson
