06-12-2019 #1
LSA swap in 1st gen - Upper Radiator Hose with CTS-V Water Pump
Good morning everyone. I've done some searches and it seems all the recommended radiator hoses posts come from those with a standard vette or F-body water pump. The LSA/CTS-V water pump outlet is further away from that typical passenger side radiator location for the upper hose which means that NAPA part number is quite a bit short.
What part numbers has everyone been using? I am looking for a molded hose, not an AN fitting setup. If it comes to it I'll just cut the NAPA hose and put a fill/cap in to extend it that 4-5" that I need but wanted to check with everyone here first.
Thanks!
