      May 2019
      18 x 10 with 5" BS 1971 A Body
      Can anyone tell me if a 18 x 10 with 5" of BS will fit my 71 GTO? I have read 5.5 is optimal but not sure if these would work. TIA
      corona,ca.
      Front or rear?
      72 chevelle.
      Quote Originally Posted by chevelletiger View Post
      Front or rear?
      That's important...I run 18x10 6.25" BS in the rear with a 295/35 tire, and have 1/2" between the tire and outer fender lip (rolled). This is on my 70 GTO which has the same front and rear fender wells as a 71.
      Feb 2017
      Bowling Green, KY
      Rocket Racing Wheels stocks 18x10 in 4.50", 5.00", 5.50" and 6.00" backspacing without having to go custom-built route! Check em out!
      http://www.rocketracingwheels.com/ro...-titanium/p678
      18x10 6" bs will work well in the rear.
      Sep 2013
      Houston, TX
      285|40R18s on 18x9 rims w/5.25 BS
      I have 285|40R18s on 18x9 Bandit rims with 5.25" BS on my '72 442 convertible. I have 1-1/2" clearance to the frame rails on the inside and about 1/2" clearance to the fender lip on the outside. My frame has not been narrowed and I haven't rolled the inside of the fender lips either. For comparison sake; a 305 series tire on a 10" wide rim with only 5" BS would increase the clearance on the frame side to 2" and would stick-out on the fender side another 1.2". Using this same scenario with 6" BS puts the 305 series tire 0.6" closer on the frame side and only stick out an another 0.2". Seems like it could work with the 6" BS!
      Here's a few pics of my set-up. The car sits way too high in the back because I've installed the wrong springs and all the heavy goodies are currently not installed on the car.
      Rodney Meyers
      72 Olds 442 Rest-mod clone
