Results 1 to 18 of 18
05-25-2019 #1
1967-1969 Camaro Speaker Kick Panels and Package Trays FS
Custom Fiberglass speaker package tray and Kick panels for 1967-1969 Camaro and firebirds
I only make a few of these while the weather cooperates with me...I'm not a business that makes these year round.....These are listed on other sites as well so quantity or availability can change any time. I'll try to keep the post updated.
I will just make a couple here and there from time to time and update this thread as much as I can - thanks
Speaker Package Tray for 67-69 Camaro's and Firebirds
- Shipped as pictured, ready for you to finish the grilles and cover to your liking. Grilles are made of 1/2" mdf.
- There is room for speakers on the outside locations and a spot in the center to utilize for a subwoofer port or opening for speaker to play through.
- Some minor blemish and prep needed for paint. To be expected from fiberglass parts pulled from a mold.
- Perfect for a show car or that pro-touring restomod
- Ships in a custom built crate 55" x 16" x 2" to protect from damage and tracking provided
$189 + shipping each ...shipping typically runs around $37-47 depending on location with California being the highest shipping rates. Just contact me for a quote.
Speaker Kick Panels for 67-69 Camaro and Firebird's
- Made of fiberglass in gelcoat and primer
- Comes with kick panels, pinch weld and mdf grill blanks, you finish with your own vinyl, paint, and grill cloth.
- Keep speakers out of your doors and have a nice low-key place to install them instead. When you use the supplied grill blanks and wrap in grill cloth speakers will disappear into the interior.
- Pinch weld replaces the trim that runs along the jamb and panel sits against that.
- Fits up to a 6.5" speaker and tweeter
- Speaker resides in the area where the factory kick panel vents were, you will lose the pull cables in the factory kicks.
- You can use use a Metra 81-6900 Baffle behind the speaker to protect it from the elements. These can be purchased on ebay for around $10 shipped.
- No Speakers are included, these are raw panels ready for you to finish and add your own speakers
- Some prep will be needed as you would any fiberglass part if your wanting to paint these. Expect some minor imperfections for something that comes out of a mold.
- Some trimming required to get a tight fit to your car
- Holds a component set with a tweeter and up to a 6.5? speaker
- May work with Factory AC but you need to remove the flapper actuator in the passenger kick panel and cap off the vacuum line. But these work best with aftermarket AC systems. Do your research.
- Non-AC Owners: Will work on Non-AC Cars IF you completely remove the cable vent pull knobs and rods. but nothing is permanent and can be reversed if you sell the car.
- If you have Vintage air that runs hoses through the passenger kick panel you will have to relocate the hoses above the kick panel.
1969 Owners PLEASE READ
These kick panels were made from a set of 67-68 style kick panels do they are a direct fit for those years. 1969 kick panels are physically the same size but there is some differences at the front top edge where it meets the dash.
It's nothing major, but EXPECT to do some minor trimming for these to fit a 1969 Camaro
$150 + shipping each for the kickpanels
Please note, I do not sell either of these "finished and ready to install" You will need to be prepared to do it yourself or have someone ready to fit and wrap these in vinyl or paint - thanks
Pics of them finished and installed are for reference only
My build thread
http://www.nastyz28.com/forum/showthread.php?t=241037
Paint Jail Experience
https://sites.google.com/site/paintjail/home
05-25-2019 #2
Currently I have one (1) Tray available and one (1) pair kick panels available ready to ship
My build thread
05-25-2019 #3Registered User
- Mar 2008
- L.A. dba Fairhope AL
- 99
