05-23-2019 #1Registered User
- Aug 2010
- 441
Pedal not returning all the way up?
I am in the process of finishing up the install of a DSE booster and master cylinder on my 69 Firebird track car. I feel confident that the brakes are bled well all the way around. I am using a Wilwood proportioning valve in the system and as far as I can tell I have no leaks. The motor also makes plenty of vacuum for the booster. The problem I am having is that the pedal doesn't want to return all the way up after it is pressed down. Everything seemed to line up well when I bolted up the booster to the firewall. The clevis pin was a little hard to line up, but I got it through. Thoughts?
Joe
1969 Firebird Project
1967 Frirebird 400 convertible
2013 Boss 302
05-23-2019 #2Registered User- Join Date
- Sep 2004
- Arizona
- 239
The vacuum booster has an internal spring that returns the pedal to it's up position.. I just returned a booster that had a problem with the internal spring.... push the brake pedal and it would not come all the way back up..... new booster, no more problem... That was my issue.
05-24-2019 #3
