    Results 1 to 17 of 17
      Jul 2009
      Cypress, TX
      Trunk upholstery
      After admiring other people’s trunks, I’ve decided to do my own. Bought the plans from Alien Enclosures and started the process a couple of weeks ago. Principally finished today and am quite pleased.
      http://s1145.photobucket.com/user/TE...5DBDA.jpg.html
      Cut the bottom out of ¾” plywood and the sides are ¼”
      http://s1145.photobucket.com/user/TE...59C0D.jpg.html
      Assembled the pieces outside the trunk, as they are self supporting.
      http://s1145.photobucket.com/user/TE...3E9DB.jpg.html
      A bit of cutting and adjusting was needed to fit the assembly in my trunk area.
      http://s1145.photobucket.com/user/TE...BD008.jpg.html
      Upholstered with ¼” foam and red perforated vinyl. Inserts are 1/32” carbon fiber sheets on ⅛” plywood backer.
      http://s1145.photobucket.com/user/TE...F3CD4.jpg.html
      http://s1145.photobucket.com/user/TE...97CF5.jpg.html
      1969 Camaro - LSA motor, 6L90 transmission, TCI front subframe, TCI torque arm rear suspension, Ford 9" rearend
      Jul 2009
      Cypress, TX
      That looks great.
      Jul 2018
      Great job
      Jonesboro, Arkansas
      Sure took space out of your trunk though.
      Carl Wilson
      Jul 2009
      Cypress, TX
      Carl, Agreed on the reduction in apparent space; however, the panels are readily removable (velcro holds the panels in place) and storage is available behind the panels on each end and behind the rear seat. I have a trunk mounted battery setup behind the passenger side of the rear seat, which is hidden by the new trunk panels.
      Jonesboro, Arkansas
      All of it looks really good. I did something similar in my Camaro. I also used the velcro to hold the panels on. I can get to the back of mine easily as well. I also have a bottom panel that covers the "trap" door to the top of my gas tank if I need to do work on it without having to drop the tank. Good job on yours!
      Carl Wilson
      Jan 2019
      How much were the plans? Sure wish you would have done 2 and sold me one
      Jul 2009
      Cypress, TX
      $87.35 with shipping. Couldn't have been much easier. Just cut out the patterns, trace around them on your plywood, and cut out the panels using your jig saw. A minor amount of adjusting on each panel was necessary to get the best fit. I still have my plans. Sell them to you for half price if you're interested.
      Aug 2010
      Richmond , Tx
      Country Flag: Philippines
      Quote Originally Posted by terrydmorgan View Post
      I will take you up on that offer! Im local too
      69 Camaro LS2, ridetech 4 link fikse wheels yada yada yada
      17 Grand Sport
      Jonesboro, Arkansas
      PLANS! what plans... LOL
      Carl Wilson
      Oakl;and, Ca
      Where's your battery located?
      Jul 2009
      Cypress, TX
      Between the rear seat and the front panel of the new trunk upholstery, passenger side.
      Huntington Beach, CA
      Any pics of the battery mounting setup you used for that?
      Newbury Park, CA
      Need a photo Chad? Mine's on the upper trunk shelf, passenger side against the trunk divider.
      Jun 2014
      Alien has a Pro-Touring Forum member discount code that has been extended through the end of the year: ae04017
      I think I've seen a pic of yours at some point? Each time I think about moving mine I measure it out and come up with it not fitting a full size optima battery. I'm also curious about supporting the bottom of the battery. Why type of plate is used and if any of the trunk floor is cut/modified to eliminate bumps.
