    Results 1 to 12 of 12
      Jun 2010
      Deployed
      Melted PS reservoir nipple/connection.
      My road course day came to an end because I melted the PS reservoir. It’s a type II pump with an integrated reservoir. Where the housing with an O ring slips into the pump, that nipple melted/deformed causing it to leak profusely. Is this common? I’m now looking into a Jones Racing metal reservoir now, but it looks like it might be too big. What other options do I have?
      1970 Camaro/DSE build
      Feb 2003
      Valencia, CA
      Very common. Exact same thing happened to me. I went with a remote aluminum reservoir and mounted it on the pass side away from engine heat. Only tracked it once after that (69 Camaro that I sold) but it seemed ok. Puked a little bit, but it may have been overfilled.
      Mountain Springs, Texas
      Do you have a power steering cooler? I’d be adding one. Oil cooler too if you are tracking the car....
      Don
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Jacksonville, FL
      Is the PS pump set up the one off of the mid mount?
      Chris
      1968 Chevy Camaro SS
      LS3/T56 DSE suspension
      Jun 2012
      South Lyon, MI
      Speedway Motors has several GM type 2 pump options with remote aluminum reservoirs. There are others out there too. They are common in the circle track crowd.
      Jun 2010
      Deployed
      Quote Originally Posted by cornfedbill View Post
      Im using the PSC pump that was provided with the Wegner front accessory drive. It’s not a dedicated track car, but adding a cooler wouldn’t hurt. I ended up buying Jones a racing fabricated reservoir. Has additional bungs for option...
      the problem was clearly heat, but hot enough to deform the reservoir but the O ring was perfectly fine!
      Newbury Park, CA
      KRC has reservoirs with a built in filter. Filters are good in any case and are available as an inline type as well.
      The GM power steering fluid is far better than anything else I've tried.
      Jun 2010
      Deployed
      Filter? For cooling?
      Newbury Park, CA
      Power steering filter.
      Jun 2010
      Deployed
      The solution has arrived....
      Jacksonville, FL
      Which one did you get?
      Chris
      Jun 2010
      Deployed
      The one with both coolers.
      Quote Originally Posted by 130fe View Post
